beogram 4004 diaphragm foto resister bulb
Not Answered This post has 0 verified answers | 1 Reply | 2 Followers
GEOMARK
GEOMARK posted on Fri, Mar 15 2013 1:54 AM
hi hopping some one can help me ..i have a beogram 4004 with a burnt bulb for the foto resistor.want to replace it but not sure of the watts and volts ..i think 20 volts. thanks
Menahem Yachad
Jerusalem, Israel
Do you mean the Photo-resistor for the sliding Ruler?
If so, it is an infra-red LED, and you can't see any visible light.
You can do a normal diode check with a multimeter, to determine if it is OK.
Unless someone has fiddled with the circuit, and destroyed it, these usually last a lifetime.
Did you try to test it by putting 20V across the terminals - then you've destroyed it for sure.
If you are referring to the lamp at the base of the tonarm, then that can be replaced by a white LED, with 1K 1Watt dropping resistor.
Menahem
Page 1 of 1 (2 items) | RSS
