DIY installation of a Beovision Harmony & Headphone connection
Answered (Verified) This post has 1 verified answer | 7 Replies | 1 Follower
carlito
carlito posted on Sat, Dec 18 2021 4:58 PM
Hello all
Have anyone of you installed the Harmony on the stand by yourselve? I consider myself handy enough to do it, just asking about the configuration and cable management
Would be happy if someone can share their experience
Thanks in advance
Carlo
kawo
Answered (Verified) kawo replied on Tue, Dec 21 2021 4:02 AM
Verified by carlito
I did both on my own, first floor stand, than later wall bracket. Video from B&O very helpful, without that would not have done it. Just to expensive stuff to potentially damage it.
As Mikipidia said, it is very heavy! Floor stand is much easier to handle as the wall bracket. just more space to work. My respect to Sig to do the job without a second person, for me it sounds almost impossible :-)
I guess next time I would ask my dealer to do the job...I am getting older :-)
The Beonic Man
Bristol
Go easy! Sounds like a big ask to me.
BV11-46, BV8-32, V1-32, BS2, P6, A1, H95, E8, BR1, Beo4, Essence
Razlaw
ONLINE
Razlaw replied on Sun, Dec 19 2021 3:34 PM
This video might answer your question….although is not on the stand.
https://www.youtube.com/watch?v=G2jS-Orimkk
Curly
FL, USA
Curly replied on Sun, Dec 19 2021 7:05 PM
There is an internal (although publicly available) video on YouTube from B&O serving as an installation how-to. I can't find it at the moment but I'm sure someone handier than I will be able to.
I actually think it looks fun and don't think it looks like a big job! Does anyone think it was really too difficult to do on your own? @Mikipedia installed his own...
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
carlito
Thanks for the answers above
Another question came up and therefore I changed the title.
How can a headphone (Beoplay HX / H95) connected to the Harmony? There is no Headphone and digital out - only Powerlink? Maybe Steve from Sounds Heavenly has an answer here....
pentalex
pentalex replied on Mon, Dec 20 2021 10:37 AM
The headphone you need to connect with Bluetooth with the tv.
Mikipidia
Installing it is not hard, just super heavy and you can not put eny pressure on the speaker wings. If you bend them it’s on you and the fix isn’t cheap. I would highly suggest it’s a two person job because of the weight and the delicate nature of the speaker wings. Stig did his on the wall by himself, Brendon did his on a rotating floorstand. It’s doable, but be sure you know what you’re doingSmile
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
kawo
Verified by carlito
Page 1 of 1 (8 items) | RSS
