Beogram 8000 Set-down Not Working Properly
Not Answered This post has 0 verified answers | 3 Replies | 1 Follower
John Francis
USA
John Francis posted on Wed, Nov 24 2021 11:12 PM
Hello All,
I have been doing a little routine maintenance on my Beogram 8000 which included lubricating the rails, cleaning and putting a recently restored dust cover back on. I notice while doing this that the detector arm and pick-up arm although parallel to each other, were not at a right angle to the rails. I adjusted both arms to correct for that. Now when I try to play a record the pick-up arm starts to drop where it looks like it should, but just before it reaches the record it moves inward toward the spindle a short distance, so does not play the beginning of the record. I tried adjusting the SO switch but that did not fix the problem. I did notice the plastic cover for the two arms binds a little so took that off to see if that might be the problem, but that wasn't it. Does this seem like a mechanical issue or an electronic one? The turntable was working fine before my arm adjustments.
Any thoughts appreciated!
John
John Francis
USA
It occurred to me that I should check to see if I moved the tonearm further into the record and see if I pressed play the tonearm still moves inward just before it sets down, it does.
Mark
San Francisco
Mark replied on Thu, Nov 25 2021 10:33 PM
You need to go through the arm tangential tracking adjustment (Aperture and Photo Control) that is detailed in the Service Manual.
John Francis
USA
Thanks, Mark! I will take a look at that today in the service manual.
John
Page 1 of 1 (4 items) | RSS
