Speculation Maybe Harmony 83" in 2022
Not Answered This post has 0 verified answers | 4 Replies | 0 Followers
Emil Jensen
Denmark
Emil Jensen posted on Wed, Nov 24 2021 6:32 AM
LInk
LG G2 will come in 83"
And C1 will come in 42" but I do not think they can get that to work in a Contour, as the Stage is to wide.
Beovision Harmony 77" 2nd Gen, Beolab 5, Beolab 17, Beosound 1, Beoplay M3, Beoplay H6, Beoplay Earset, Beoliving Intelligence
seethroughyou
UK
83 inches on a TV. The world needs 83 inch panels as much as the Pope needs condoms. 83 inches…..??!!
Present: BL90, Moment, Core, BL6000, CD7000, 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4.
Mikipidia
Need and want are very different.
I would say they should make it happen as they could easily do it and sell it at half the price of the 88”. Ihmo it’s a better idea than the 88” now.
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
vlohjr1
Mikipidia:
I would say they should make it happen as they could easily do it and sell it at half the price of the 88”. Ihmo it’s a better idea than the 88” now. New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
Would the 83 support 1st gen harmony apart from the grill?
Mikipidia
In terms on bolt pattern and app etc yes. Iirc the main difference was for the weight of the 88” with all the covers on the back. So since we don’t know the weight of the 83” or of the wing covers its hard to say. The mechanism is the same for the wings but it has 3 different springs in it, those can be switched over though. If it’s other parts like the legs that push up, then I don’t know fully yet.
Page 1 of 1 (5 items) | RSS
