Test Flight App --- TUNEIN
Answered (Verified) This post has 1 verified answer | 40 Replies | 2 Followers
Gary
Dublin, Ohio
Gary posted on Fri, Nov 19 2021 11:04 PM
Am I missing something or is it no longer possible to save favorite stations in the TUNEIN section of the latest Test Flight for B&O?
Nidi
Answered (Verified) Nidi replied on Sat, Nov 20 2021 3:28 PM
Verified by Nidi
Helo MrAnderson, my wish to christmastime…..
Please integrate a Sleep-Timer (30, 60, 90min) button in the menu……It would be easier than always adapting the alarm time to the bedtime…
liviu_o
@ Mr Andersen- also I cannot start tunein stations from BO app on Essence MK1….only way to listen is to start tunein on iphone and stream to Essence 😔
Any way to fix this?
Frederik
Belgium
I do not heave a Mozart product yet to test B&O Radio but from the interface I see in the app it seems that a few additional functionalities would be required to get on par with TuneIn:
  • It seems you can only have 4 favourites mapped to the MyButtons. It would be nice to be able to manage favourites like in TuneIn where you can edit the order and map them to the number keys on the BeoRemote One.
  • In TuneIn you can manually add custom URLs for streaming of stations that are not directly available on TuneIn. I don't think B&O Radio provides this function?
  • In TuneIn you can check the bitrate of the stream, which can be useful from time to time.
If these functionalities can be supported the only remaining plus of TuneIn would be integration with other products. In general, I think it would be nice to have TuneIn on Mozart and B&O Radio on the other products. Not sure how feasible that is however.
Hiort
Sweden
Hiort replied on Fri, Nov 26 2021 8:00 PM
New release tonight.
Same problems for me unfortunately…
ngnear
ngnear replied on Fri, Nov 26 2021 8:35 PM
Didn’t work for me either until I “personalised” the Radio menu. Then the favourites reappeared.
Tim
Hiort
Sweden
Hiort replied on Fri, Nov 26 2021 8:54 PM
ngnear:
Tim
Not sure where you do that…
There is a setting where you can toggle eg favourites on / off but It did not help.
mbolo01
Louannec - France
Same here, I don’t see TuneIn favorite fixed
ngnear
ngnear replied on Fri, Nov 26 2021 9:17 PM
Hiort:
Yes, this where I toggled one of the fields off and then back on. The favourites then appeared.
mbolo01
Louannec - France
ngnear:
Yep, to see the favorite you must turn all the other options ON …. Another issue to be fixed by B&O
Hiort
Sweden
Hiort replied on Fri, Nov 26 2021 9:42 PM
mbolo01:
Yep, to see the favorite you must turn all the other options ON …. Another issue to be fixed by B&O BS Moment, BS Core, BG 4002, BC 4500, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
No luck…
mbolo01
Louannec - France
Hiort:
No luck
You must close the app (swipe up in IOS) for the change to be effective (another bug)
Millemissen
Flensborg, Denmark
The only thing that helped me, was to toggle on ALL 4 categories.
Usually I only have the first = Favourites set to on (that is what I need).
Afterwards you can toggle off those that you don’t need….and the Favourites appear Lets have a Party !!!
Not very intuitive, but it worked.
mbolo01
Louannec - France
mbolo01 replied on Fri, Nov 26 2021 10:26 PM
Millemissen:
Up to the point you close/start the app. The choice is not persistent unfortunately
mbolo01
Louannec - France
mbolo01 replied on Fri, Nov 26 2021 10:29 PM
Also, when all radio options are turned on, despite you are only a TuneIn user, B&O radio page is showing « my radios » which are not my radios
Millemissen
Flensborg, Denmark
mbolo01:
What do you mean by ‘close/start the app’?
mbolo01
Louannec - France
mbolo01 replied on Fri, Nov 26 2021 10:32 PM
Navigating in B&O radio localisation pages crashes the app
Page 2 of 3 (41 items) < Previous 1 2 3 Next > | RSS
