missing BG4000
Not Answered This post has 0 verified answers | 101 Replies | 0 Followers
Craig
Yarm, United Kingdom
Silver Member
Craig posted on Tue, Oct 19 2021 11:56 AM
Following a protracted delivery process Justin was finally able to get this to me, seems it had fallen off DHL's radar a week or so ago and we feared the worst........
Craig
Silver Member
This is the way to ship a Beogram around the country........
Craig
Silver Member
Despite going walkabout the packaging appears non the worse for the ordeal.....
Craig
Silver Member
Doesn't look like anything has moved around in the box...
Craig
Silver Member
All still very secure.............
Craig
Silver Member
A very clean looking unit....comes with a set of capacitors and laser printed mounting brackets from Rudi, along with some LED's for the control panel.
Craig
Silver Member
Craig replied on Tue, Oct 19 2021 2:12 PM
The unit is described as working with the following issues:
Neon lamp for speed indication not working
Tone arm refuses to move up or down
Some time on the work bench will confirm that no other problems exist.
Craig
Silver Member
Took a peep inside.....reasonably clean with no obvious footprints indicating previous activity.....
Craig
Silver Member
However the carriage drive belt looks very "baggy" and most likely loose.....
Craig
Silver Member
The solenoid and assembly look gummed up, they don't move freely which will be contributing, if not the cause, to the tone arm woes.....I've also noted that the bottom leaf spring on the middle switch is not straight, I suspect its not breaking when the solenoid operates....
Craig
Silver Member
Teased out the linkages and springs for a good clean and lubrication......
sonavor
Texas, United States
Craig:
Now that is a properly packed Beogram 4000.
-sonavor
Craig
Silver Member
Indeed Sonavor......almost bullet proof!
The lift arm was very very difficult to move back and forth....almost immovable with  my finger.
Craig
Silver Member
Bit of persuasion and some light oil helped to free the assembly up.....
Craig
Silver Member
I noticed at this point that the nylon roller which supports the carriage on the steel rail upon which it runs was skewed off to one side, on investigation i found the screw was tightly screwed in but looked cross threaded......
Page 1 of 7 (102 items) 1 2 3 4 5 Next > ... Last » | RSS
