Smoking Beomaster 5 - possible capacitor
Not Answered This post has 0 verified answers | 5 Replies | 0 Followers
Macattack1
Macattack1 posted on Mon, Oct 11 2021 4:28 AM
hi guys , I’m hoping someone can help with an issue I just experienced with my Beomaster 5. I hadn’t used it for a while and plugged it in. After about 30 seconds it started making a terrible noise and I quickly turned it off at the power point. It started smoking and smelling really bad . I opened it up and found something on the mother board had failed . I think it may have been a fuse but not sure. I’m not really sure watt to do but thought someone might be able to help me.
laseralex
Do you have a photo of the failed component?
Also, do you know how to solder replacement components if we can determine the correct replacement part?
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x Essence Remote  • 1x Beoremote Halo
Macattack1
Yes I do have a photo and I think I could solder if we found the failed component.
Macattack1
Hi Laseralex
thank you for your reply. Did you see the photo I posted of the item that exploded?
laseralex
Macattack1:
No, I don't see any photos in any of your posts.
marexy
marexy replied on Tue, Oct 12 2021 6:32 PM
May be many things...you can send me PM with photo.
Page 1 of 1 (6 items) | RSS
