Is the beoplay M5 too much BASS ?
Not Answered This post has 0 verified answers | 3 Replies | 0 Followers
donnghia
donnghia posted on Fri, Sep 24 2021 6:23 PM
Hi, I'm consider a used beoplay M5, but I many people told me that it has too much bass compare to beolit 20 and cannot be adjust by the EQ. Is that true or it has been fix by firmware update?
Many thanks
Beobuddy
Utrecht, The Netherlands
You can adjust the amount off bass.
First you can select where the M5 is located, Corner, Wall or Free.
Then you have the ability to adjust the sound with the help of Beosonic. It allows you to fine tune the sound with a touch of your finger.
Beobuddy
You can easily fill the room with a lot of sound with lots of bass.
For a smaller room it might be a bit much sometimes. I like the bass from the M5 more than coming from a BS1(mk2). I have both so compared.
PIcture of the Beosonic in B&O's app:
Curly
FL, USA
Curly replied on Fri, Sep 24 2021 10:14 PM
Agreed. You can EQ down the bass in the M5 if you wish.
I love the sound of the M5 and when I owned a BS1, I was always jealous that the M5 sounded so much more full. IMHO, the M5 is a great product.
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Page 1 of 1 (4 items) | RSS
