Finally! Beogram 400x lid without seam
This post has 17 Replies | 1 Follower
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
leosgonewild Posted: Tue, Sep 21 2021 3:30 PM
This has taken me over a year to get manufactured.
My first order had seams in it, because it was glued together.
I was close to order from a guy in Denmark, but it turned out that those lids are also pieces glued together.
The factory said it was not possible to make this without seams. In this day and age it is not allowed to say that “No” doesn’t mean no, but I didn’t take no for an answer. I simply instructed them how to do it the way I meant it could be done.
So I present to you:
The LeoLid 4000 Big Smile
sonavor
Texas, United States
Posts 3,718
sonavor replied on Wed, Sep 22 2021 2:46 AM
Very nice.
Can you show some more photos that include the back part of it and the mounting to the dust cover hinge?
-sonavor
mr_anders_son
sweden
Posts 1,705
FABYes - thumbs up
BeoVision Eclipse 55"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
Mikipidia
Posts 2,154
Mikipidia replied on Wed, Sep 29 2021 12:00 PM
Very nice!, when is the protective plastic coming off?Smile
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
When I get the new aluminum strip finished Big Smile
matador43
Posts 1,362
matador43 replied on Wed, Sep 29 2021 12:54 PM
Could we have some sense of costs?
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
200€
matador43
Posts 1,362
matador43 replied on Wed, Sep 29 2021 6:14 PM
Thank you Leo Wink
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
I’m trying to reproduce the aluminium strip/band in the lid. I need it to be 0.2 or 0.3 thickness. Can anyone point me in direction of where I can get this?
I can’t buy the replica avaliable on eBay. The outer portion of my lid is not the same as original.
matador43
Posts 1,362
matador43 replied on Mon, Nov 8 2021 12:25 PM
Awaiting a better solution but quite sure you already think of it, I would try aluminium adhesive tape (for chimneys, you know?) and nowadays hard to find Letraset or Decadry at the right size (5 or 6 mm from memory). Helvetica regular or light: not spot on but the most approaching I've found.
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
Sanding in progress.
Next is print.
Then a layer of satin clear coat.
Unless anyone means I should choose different clear coat???
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
Oh, and how do you print on aluminum??
trackbeo
Posts 640
trackbeo replied on Tue, Nov 16 2021 3:22 PM
Via silk screen.
Or maybe... don't Maker/DIY 3D-print shoppes do laser etching nowadays?  The aluminum would have to be anodized, because it can't actually etch metal, only the surface coating.  But this includes paint, so you could put on the clear coat and then etch that away, and wait a few years for it to show a bit more.  (This is assuming you didn't mean the question humorously... You are so studly-DIY, one might imagine...)
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
It was a serious question Smile
I tried with printing on photo paper and ironing on, but with no luck.
Thanks for mentioning silk screen. I did this in art school 20 years ago, but had forgotten about the technique.
Will contact a local business tomorrow. Big Smile
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
trackbeo
Posts 640
trackbeo replied on Wed, Nov 17 2021 3:18 PM
Studly.  (As previously stated.)  Now all you have to do is make a hundred or so *before* your own, so it's fuzzed-up like the original got, during the factory run!
leosgonewild
Helsinki, Finland
Posts 2,361
Silver Member
The aluminum strip was made by cutting a 0.5mm sheet. I then sanded away the cutting marks, before I sanded the top to give it a brushed look. I then had an artist silk/screen print the text for me. Finished it of with matte clear coating.
Page 1 of 1 (18 items) | RSS
