Deezer only 30sec tracks
Not Answered This post has 0 verified answers | 7 Replies | 1 Follower
steve1977
steve1977 posted on Sat, Sep 18 2021 9:45 AM
I’m subscribed to deezer hi-fi. I’m playing through the b&o app, but songs only play the first 30sec. Is deezer no longer supported by b&o?
Things working well via airplay.
1990
1990 replied on Sat, Sep 18 2021 10:00 AM
I've had this a few times. You have to log out from Deezer and then log in again on the product itself. Seems to be some sort of time limit on the connection to the Deezer server?
Curly
FL, USA
Curly replied on Sat, Sep 18 2021 11:51 AM
It’s not recognizing your paid hifi subscription for whatever reason.
If you have a free subscription, then this what you get — 30 sec clips.
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Essence Remote
Previously: BeoSound 1 non-GVA
steve1977
Log out in b&o app and log in again in b&o app?
Stan
Chicago-area USA
Stan replied on Sun, Sep 19 2021 5:22 AM
I believe you need to log out from the B&O app and the Deezer app (on all phones and tablets that might be logged in), but also go into your product(s) and select "configure", then "your content ", then "Deezer" and also log out.  Although, this happened to me once, and I couldn't fix it doing the above so I eventually cancelled my subscription.  Then picked it back up a while later.
steve1977
Stan:
Mmh… That indeed sounds quite inconvenient… So, seems i’ll have to explore other options again for streaming.
All my attempts to get airplay 2 to work well seemed to have failed. It’s not sufficiently stable.
All my attempts with roon are better, but also similar issues.
NL actually is rather smooth, but dlna implementation in the app is poor and deezer seems to face the login issue at times.
So, it brings me down to chromecast, which i dislike as a protocol as i cannot add/remove individual speakers easily, but it actually works quite stable. So, this may be the only way and it works with deezer and spotify. Just no way to make local media work? Or maybe it does with roon? Maybe i check how roon / chromecast combo works? Any experience from this group?
Rolf 2
Germany
Rolf 2 replied on Sun, Sep 19 2021 8:52 AM
Hi, I faced  the same issue recently. I contacted Deezer hifi support and here is what they said:
"Account is 100% correct, I emptied data here, please see if Deezer is up to date.
If yes:
You can now do the following:
Close Deezer on any device that you may be signed in to
Assign a new password for your user account under this link
Delete Deezer from the BEO app
Turn off your device for 1-2 minutes
Turn it on again
reconnect your Deezer account
Sign in with your new password"
I did it two times, but nothing changed, still 30 s track time.
After the answer deezer support was no longer responsive.
I asked B&O support:
"To try to fix the problem, please log out of your Deezer account in the Bang & Olufsen app (under Settings (male symbol top right) - Music) and on your television and then log in to your again Deezer account. Does the problem persist after that?"
No change. Next try:
"We're sorry to read that the issue with Deezer persists. Please try to reset / change the password of your Deezer account from a computer and log in to Deezer on all your devices (Beosound Moment, Beovision Eclipse) and the B&O app to see if this helps."
At this point I realized, that I had missed to change my settings in the BV Eclipse. I did so, and only on then Eclipse this time, and now everything works fine, songs are playing as it should be.
Maybe there is one setting that still needs to be changed?
Kind regards
Rolf
1990
1990 replied on Sun, Sep 19 2021 11:01 AM
For me it worked to log out and in again on the product settings page (accessible through the App or the IP address).
Page 1 of 1 (8 items) | RSS
