BEOSOUND 5 WITH BEOMASTER 5 SPEAKER SHARING WITH BEOSOUND 9000
Not Answered This post has 0 verified answers | 1 Reply | 0 Followers
rocky
rocky posted on Mon, Apr 19 2021 5:31 AM
Looking for easiest way to share my Beolab 12-2 speakers between my Beosound 5/Beomaster 5 and Beosound 9000.  Is there a switch that can do that or am I restricted to disconnecting the cables every time I want to switch?
Thanks......
stefan
200 miles from Struer
stefan replied on Mon, Apr 19 2021 8:54 AM
I'd try to connect the Beolabs to your BS9000, connect BS5 (BM5) with Masterlink cable to BS9000.
Now set BS9000 to audiomaster - A.OPT1 - if no Beovision is involved) and set BS5 to NO AUDIOMASTER.
You will have five sources - CD, RADIO, A.AUX, N.RADIO, N.MUSIC.
Whatever source you select, it should activate the BL12 and play the correct source (depends on software in your BS9000)
Hope this helps
Stefan
Page 1 of 1 (2 items) | RSS
