question wifi setting beosound1 and beoplay m3
Not Answered This post has 0 verified answers | 6 Replies | 0 Followers
shell65
shell65 posted on Sat, Mar 27 2021 4:34 PM
Hi guys,
Have just seen this setting but I dont understand what it actually controlls.
The setting text is :
You may select options to modify product WiFi behaviour.
Allow WiFi roaming when product is in standby
What does that mean when I put it on?
Are the devices also kind of WIfI repeaters?
Thanks in advance for your view.
Regards
mbolo01
Louannec - France
This setting recently appeared on all devices with the latest software update and to be honest one can only guess what it made for as B&O rarely or never communicate on changes.
Maybe you can open a ticket with B&O asking about it?
leosgonewild
Silver Member
Maybe this will shine some light:
https://metis.fi/en/2018/11/roaming/
I guess that it is for larger houses with multiple access point.
Just guessing.
Millemissen
Flensborg, Denmark
Would be nice to get an official explanation for this.
I did read that too.
My thoughts - when I read it, were - that it is a setting that lets the device/s keeps the connection to the wifi even when ‘asleep’/in Standby mode.
Meaning making a faster connection possible, when you start using it.
Some times the app takes a while to recognize the devices (that are on wifi) - this could make this process faster.
However, maybe I also am only guessing.
StKong
Copenhagen
This is good news for apartments in areas with Wi-Fi congestion, I gather.
bab
bab replied on Fri, Apr 2 2021 12:53 PM
So what you're suggesting is that it's not really the roaming part that is beneficial, but the fact that the B&O product stays connected to Wi-Fi even while in standby mode? This would make sense (assuming that without this feature enabled, it always needs to re-attach when it wakes up - not sure this has been 100% confirmed though...)
StKong
Copenhagen
bab:
Mine don’t seem to disconnec from WiFi during standbyt, but one unit can get stuck on a more distant access point than the nearest and therefore suffer from poorer signal. This new function might mitigate this.
Page 1 of 1 (7 items) | RSS
