Line-in input delay—using a Beoplay A9 (or any B&O speaker) with a musical instrument
Not Answered This post has 0 verified answers | 4 Replies | 0 Followers
measuring_cups
measuring_cups posted on Tue, Mar 23 2021 3:03 PM
I just purchased a Beoplay A9 (4th generation w/ Google assistant) and connected it to my computer via line-in to use it as a speaker for my midi keyboard.
Unfortunately, there is a slight delay (probably ~50ms) that makes it unsuitable for playing an instrument in real-time. If I connect any other speaker to the computer there is no delay, so I know it is the A9 specifically that is causing the issue.
I found another post on the forum about a line-in delay setting in the sound configuration, but it doesn't solve my problem for a few reasons
  1. I think this person was talking about much greater delay (they mentioned 1-1.5 second delay for bluetooth) that was impacting audio/video being out of sync
  2. When I looked at the line-in settings, there was no delay checkbox for me
  3. There is a "Disable delay" checkbox in the optical settings, even though this speaker has no optical input. When I select "Disable delay" here, it displays the message "Delay disabledLine-in delay disabled" exactly like that, with no space. So it looks a little buggy, and I can't tell if it is actually setting the line-in delay from the optical settings page or not. But it does not solve the problem.
Does anyone have any experience using the Beoplay A9 for real-time audio like this? Is there another B&O speaker I could get instead that would not have this problem?
Thanks!
Carolpa
measuring_cups:
it has!
it is the same input as the LineIn (if the last version is the 4th generation)
measuring_cups
Oh! Well, that would explain why the setting is in the optical section and seems to apply to both. Changing the setting doesn't seem to make a difference though. Sad
Stan
Chicago-area USA
Stan replied on Tue, Mar 23 2021 10:30 PM
It might be the lag of the sound processing within the A9.  The more recent B&O active speakers contain DSPs (digital signal processors) to "voice" them - fine tune the audio response to optimize the sound for the drivers, amps and enclosure - this isn't free.  You win better sound.  You lose a bit of latency.  I doubt that playing musical instruments is a use case R&D give much consideration.  Then again, this is all speculation.
measuring_cups
I bought a TOSLINK cable to test the delay with optical and it works great!! I think it is a bug in the app that the delay setting only applies to optical and not line-in.
Thanks Big Smile
Page 1 of 1 (5 items) | RSS
