BeoVision 4 power on without BeoSystem
Answered (Verified) This post has 2 verified answers | 15 Replies | 4 Followers
krisons
krisons posted on Sat, Feb 2 2013 10:50 PM
Dear friends,
I have just bought a BeoVision 4/42 plasma panel alone to connect with my PC.
The seller assured me that it powers on automatically when detects an incoming VGA signal, and now I know that is not true. I have read tons of manuals and docs over the internet and have not found a solution.
I understand, that BeoSystem send a signal to Serial Port to control it power state. Can it be simulated or called by something else?
Please help me understand how can I power on plasma without BeoSystem.
Thank you!
jdthegiri
Verified by jdthegiri
I have just spent 4 days trying to do the same thing with a BV4 / 50 ......................................... Dont worry there is hope (not an expensive BEO4 remote)
Unplug the serial, picture sensor and the IR leaving just power and a working sorce
Then using a Panasonic or universal remote programmed for a panasonic plasma hold the remote to the bottom left corner of the screen, pointing in towards the screen frame seal (the original IR sensor is hidden behind the frame) and you should hear a faint "boing" noise.
And yes it is just a rebadged Panasonic, but that still makes them great !
Good luck
krisons
Verified by Basilis94
Yes, it works.
Just use native Panasonic or universal remote set to Panasonic codes. You need to point it in the little hope in aluminium frame from below.
Good luck!
jdthegiri
Good luck
kallasr
Germany
Lots of infos on this site if you are a silver/gold member.
The service manual shows this:
(BV4-50-D8_service-eng.pdf)
Ralf
krisons
Thanks a lot!
Now I need to find a remote.NDo you know the model of the Panasonic plasma which is inside?
Can you please provide me a model name of your remote?
oleg
kallasr
Germany
What is the resolution of your 4-42?
It sould be something like TH-42P...
- PW for wide screen (852 x 480)
- PH for HD (1.366 x 768)
- PF for Full HD (1.920 x 1.080)
Just check the panasonic website for details. Look for professionla plasma display.
I used to run a TH-42PWD6 (as far as I remember) with a Beosystem 2.
Ralf
PS: a list I found that I used while searching for a display
Full HD TH-42PF20 2010 G13 1.920 x 1.080 Px        2.073.600
Full HD TH-42PF11 2008 G11 1.920 x 1.080 Px       2.073.600
High Definition TH-42PH20 2010 G13 1024 x 768 Pixel           786.432
High Definition TH-42PH12 2009 G12 1024 x 768 Pixel           786.432
High Definition TH-42PH11 2008 G11 1024 x 768 Pixel           786.432
High Definition TH-42PH10 2007 G10 1024 x 768 Pixel           786.432
High Definition TH-42PH9EK 2007 G9 1024 x 768 Pixel           786.432
High Definition TH-42PD12 2009 G12 1024 x 768 Pixel           786.432
High Definition TH-42PHD8 2006 G8 1366 x 768 Pixel     1.049.088
Standard Def. TH-42PS10 2007 G10 852 x 480 Pixel           408.960
Standard Def. TH-42PG9 2007 G9 852 x 480 Pixel           408.960
Full HD TH-50PF20 2010 G13
Full HD TH-50PF11 2008 G11
Full HD TH-50PF10 2007 G10
High Definition TH-50PH20 2010 G13
High Definition TH-50PH12 2009 G12
High Definition TH-50PH11 2008 G11
High Definition TH-50PH10 2007 G10 1366 x 768 Pixel       1.049.088
High Definition TH-50PHD8 2005 G8 1366 x 768 Pixel       1.049.088
High Definition TH-50PD12 2009 G12
High Definition TH-50PHW6 2004 1024 x 768 Pixel           786.432
High Definition TH-42PHW6 2004 1024 x 768 Pixel           786.432
Standard Def. TH-42PWD6EX 2004 852 x 480 Pixel           408.960
krisons
Thank your your help!
I have ordered a remote, so I will inform with a result when it arrives!
Oleg
rudyfonseca
Silver Member
So you can put it on ? please tell me details
thank you i have de same problem with a beovision 4 full hd  type 9080 fro 4 -2008
rudyfonseca
Silver Member
krisons
Yes, it works.
Good luck!
rudyfonseca
Silver Member
ok i have two remotes from panasonic tvs but i can not put in on with this 50 " beovision 4 next step for me is remove the aluminium frame
also i have another  37 " beovision 4 but in this the panasonic remote is working
any new idea is welcome
thank you
marexy
marexy replied on Mon, Apr 12 2021 7:30 PM
that is an old topic but... i just opened BV 4-50  and find out that is just nice packed Panasonic TH-50PH9 display plasma.
Now the problem..i connect PC i can only see part of the desktop as it is in ZOOM mode :( and can only connected via VGA port.
I did try to connect via DVI to HDMI to my computer ..but no luck..dark screen
And i can enter menu on TV but no option to set the picture correct.
Any hint to fix that ?
I
kallasr
Germany
TH-50PH9 display plasma is HD ready only, so be sure to feed the right solution with your PC. And the right Hz (50, I guess). Do you have a Panasonic remote to control the screen?
Ralf
marexy
marexy replied on Sat, Apr 17 2021 12:49 PM
problem fixed :)
BV4 is playing from my laptop just nice :) via VGA input
It is not full HD but 720p i think 1366 x 768 Pixel
Picture is briliant as plasma should be.
Ii's Panasonic TH-50PH9 monitor. Beovision model 4-50 Type 9021 serial : 202....
Next i hope can bring it to life via HDMI input.
cclr
cclr replied on Thu, May 13 2021 9:34 AM
Hi everyone,
I have the same problem, I just purchased a Beovison 4 65 - type 8991 with a beosystem 2 but without cables.
I do not even know if the beovision work since I cannot turn it on, I try with some panasonic modele using my logitech harmony but dit not manage yet.
Do you have any advise such as panasonic plasma modele, location of the ir sensor on the 4 65, things I could check,...
Have a good day,
Loic
Update: problem fixed also on my side thanks to this post.
I remove the back of the tv to understand, I was happy to see a red ligth inside and I finally understand the location of the IR receiver, it is in the back at the vertical of the supports that allow to fix the beovision to the wall stand.
Using the logitech IR blaster and the "driver" for Panasonic TH-65PHD, the TV switch ON!!!
Next step, hdmi to vga for beovision with audio extractor SPDIF for bose lifestyle.
What a screen!!
Risketos
Hi Cclr.
I am about to purchase a Beovision 4 65 with a beosystem  2 same as you. Type 9091, item 1819663 serial 21417656
I would like to be able to use It as a Televisión controled by Chrome Cast or FireTv.
I see you have turned It on using a "Panasonic" remote control that is helpfull to be sure que TV screen works fine.
I assume maybe I will need to buy a beosystem 3 have you found any other solution?
Page 1 of 2 (16 items) 1 2 Next > | RSS
