Correct settings of NL/ML converter for two-ways communication
Answered (Verified) This post has 2 verified answers | 8 Replies | 2 Followers
mmmoller
mmmoller posted on Tue, Mar 2 2021 12:19 PM
Hi all,
I hope that you can help me with this issue.
Please look at the photo of my setup. I need help regarding two ways communication. How must I setup the NL/ML converter in order to play NETRADIO stations on my ML TV’s? Change channel etc.
Thank you in advance
Link https://postimg.cc/xcqxn333
Living Room: BeoVision 7-55 MKII / BeoLab 7-6 + BeoRemote One +  2x BeoLab 8002 + BeoLab 2 + 2x BeoLab 6002 + BeoSound 9000 MKII + BeoSound Core + BeoCom 2 + BeoLink Gateway + BLC NL/ML
Master Bedroom: BeoVision 11-55 MKIV + BeoRemote One + 2xBeoLab 6000 + 2x BeoLab 4000 + BeoTime + BeoCom 2
Guest Bedroom: BeoVision 6-26 MKIV + BeoRemote One + BeoCom 6000
Home Office: BeoVision 10-32 + BeoRemote One + DVD1 + BeoCord V8000 VHS + BeoSound 8 + BeoSound 1 (CD version) + BeoPlay A1 + BeoCom 2
Sewing Room: BeoVision 10-40 MKII + BeoRemote One
Bathroom: BeoPlay M3 + BeoRemote One
jgraefe
Verified by mmmoller
mmmoller:
Hi jgraefe,
The software on BS9000 is 2.0.
Now, when I press NMUSIC on BeoRemote One in the living room my BV7-55 turns on NETRADIO on the Core via BeoSound 9000. However, on the display "PHONO" appears. Anyway I'm able to fully control the CORE via the IR eye – turn on NRADIO, change radio channel etc.
This is currently not possible on the rest of the ML TV's.
Its like mine
I switched my Beosystem 3 to Option 6 and the Converter to Videomaster. In this Version you can choose in the Converter Menu for example dvd and Tell him to take music from the Core. To choose this on my beo4 i have to press link + dvd. On my beolab 3500 only dvd.
So i can also use cd on my Beolink Speaker Big Smile
BS9000 + BS Core + Beosystem 3 + BL8000 + BL4 + BL2 + BL7-1 // BeoVision 7 32“ + BL8000 // Beoplay M5 // Beoplay S3 // 2x BL3500 // 2x BeoPlay A6 + 2x Essence Remote // 2x BeoSound 8 // Playmaker + BL6000
Carolpa
mmmoller:
Hi all,
I would try the next setup (maybe a sound delay between NL and ML, but that can be solved).
connect the Core to your (W)LAN (no IR)
integrate the Core as a Primair Source in the BV11
connect the BLC to your (W)LAN and ML
program the BLC as Source Center
jgraefe
what Software is Running on your BS9000?
mmmoller
Hi jgraefe,
Guy
Buckinghamshire
ONLINE
Guy replied on Wed, Mar 3 2021 10:33 AM
According to this thread you need SW2.2 to use N.RADIO or N.MUSIC on your BS9000: https://forum.beoworld.org/forums/t/23350.aspx
The thread also includes a link to detailed instructions for upgrading SW, posted by Keith.
And PHONO is displayed instead of N.RADIO because it uses the same (old) IR code.  You will probably also find that selecting N.MUSIC indicates A.TAPE2, for the same reason.
jgraefe
mmmoller:
Hi jgraefe,
Its like mine
mmmoller
Thank you very much. I'll try that out!
Also thanks to Guy for linking to a relevant thread regarding this issue.
Carolpa
mmmoller:
Hi all,
Carolpa
post sent ............but awaiting moderation..........
mmmoller
That sounds interesting – good tips. Thanks Carolpa.
Actually I already have a NL/ML delay box, but I'm not sure what the delay settings should be set at. All my NL products are hardwired (expect the M3 ofc.)
Do you have any experience in this area?
Page 1 of 1 (9 items) | RSS
