Beoremote One Faulty?
Not Answered This post has 0 verified answers | 1 Reply | 0 Followers
BenSA
Durban, South Africa
BenSA posted on Thu, Jan 28 2021 10:25 AM
Hi
I have bought a 2nd hand Beoremote One. I am trying to use it as a Beo4. I have selected Beo4 Audio on the menu but when I press radio, or cd etc... nothing happens. The screen works perfectly. I did check if the IR Transmitters light up using my phone camera but they don't. Does this mean that it is faulty or am I doing something incorrectly. I have another Beoremote which I can get to work perfectly. Just wondering if there is an IR setting I don't know about.
crossbytje
I don't think the IR frequency B&O uses is visible on a phone camera. Just checked with mini and I don't see it either. It does work however.
There's a menu option in the list somewhere where you can enable of disable the IR signal.
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
Page 1 of 1 (2 items) | RSS
