New product: BeoPlay EQ
Answered (Verified) This post has 2 verified answers | 76 Replies | 0 Followers
kuyttendaele
kuyttendaele posted on Fri, Jan 22 2021 7:29 AM
New earbuds:
https://fccid.io/TTUBEOPLAYEQR
And a charging case:
https://fccid.io/TTUBEOPLAYEQC
Mike
Odense, Denmark
Answered (Verified) Mike replied on Thu, May 6 2021 6:33 PM
Verified by keyaltos
This leaked image is supposedly the Beoplay EQ - ANC
Mike
Odense, Denmark
Answered (Verified) Mike replied on Tue, Jul 27 2021 4:13 AM
Verified by Somerandomguy
Nice found, thanks.
cloud.video.taobao.com/play/u/1656561497/p/1/e/6/t/1/319752791074.mp4
https://ibb.co/6Bmw9mh
https://ibb.co/y5ZkTDz
https://ibb.co/qBcR0g1
https://ibb.co/xCq0FJh
https://ibb.co/Wx3qNJt
https://ibb.co/zhdc8HZ
https://ibb.co/YB8jsqg
https://ibb.co/5K0NdTy
https://ibb.co/pPTqKR9
https://ibb.co/xXfhSJr
https://ibb.co/9Wdw5Hg
https://ibb.co/4mWp3QM
https://ibb.co/qDDH3Yc
https://ibb.co/TmWB7D4
https://ibb.co/tXzjNPC
https://ibb.co/rMXr5Xs
Somerandomguy
Official release article
https://www.phileweb.com/sp/news/d-av/202107/28/53273.html
Google translate works quite well. You'll see the two colour schemes in the pics
Csaba
Oslo, Norway
Csaba replied on Wed, Jul 28 2021 5:17 PM
I really don’t like that they seem to have made it more bulky with that protruding «fin» that presumably does things with ANC. Making it something other than round is like reintroducing the notch on a future iPhone that didn’t have it any more. But the charging case looks sweet.
Stan
Chicago-area USA
Stan replied on Sat, Jul 31 2021 8:19 PM
I am being optimistic in hoping that the odd shape better holds them in your ear, like the fins on the "active" E8s. Time will tell, although I don't think there is anything especially magic about the E8s round shape.
I do like the flatter shape of the case.  I find the E8 case not very pocket friendly.
Millemissen
Flensborg, Denmark
John o’ Manchester - video here:
https://youtu.be/wdmUsGc8yPw
Bestwick8
Will these be able to carry lossless ?
matteventu
Bestwick8:
No Bluetooth audio device to date is capable of streaming lossless audio.
Bestwick8
So what happens when you try to play a lossless song through Bluetooth ? Does it keep skipping or just plays a compressed version ?
Bestwick8
Finally got these, only complaint is volume is quite low when using it with my iPhone.
Any solutions ? Already tried messing with the volume limit on my iPhone and transparency modes on the app, even at max volume it is rather quiet.
Bestwick8
Mikael
Denmark
Mikael replied on Wed, Aug 18 2021 12:00 PM
Sounds like you need a better (tighter) fit in your ears. In ear headphones can lack quite some volume is there isnt a good enough seal.
Beovision Eclipse gen2 (GX) w/ floorstand, Beolab 14.2, 4 speaker Shape and ATV4/Chromecast.
Beoplay A9mk4 GVA, Beosound 1 GVA, H2, H3, H8, E6, Beoplay EQ
Bestwick8
Yeah I’ve tried all of that, even tried using the memory foam, but no luck. The only thing I can think that will work is a software update increasing the volume limit, I’m willing to sacrifice the battery life for the volume
Csaba
Oslo, Norway
Csaba replied on Thu, Aug 19 2021 11:36 AM
Can you describe how low the volume is? Any other headphones or earphones to compare to and their volume percentage? Hard to understand what you define as low volume.
I suppose you have charged your earphones all the way up? One article on the B&O support page for another pair of Beoplay headphones suggest that battery level might impact the volume, but it's more of a sudden drop in it. With speakers it might be caused by overheating.
I was wondering if it exchanging it for another pair would give you a better idea. Otherwise it must be a software fix if the eartips make no difference or the way you put them in. I wonder if others have reported the same issue...
Chris Townsend
Qatar
I’ve just tried them. I like the fit and the sound was very good, but not as good as my Earpod Pros. The volume was ok but nothing special but the controls would absolutely drive me mad.
I spent 15 minutes trying to connect them to my iPhone, and in the end just used the shops IPad! I managed to advance the song once and then it didn’t work again. Turning the ANR on and off worked initially, and then rather comically randomly kept coming on and off throughout a song.
Chris Townsend
Qatar
I’ve just tried them. I like the fit and finish over my Earpod Pros, but and although the sound was good it just wasn’t as good as those. Nor was the volume.
I spent 15 minutes trying unsuccessfully to contact them to my iPhone, and then just used the shops iPad.
The touch controls worked initially as I fast forwarded a song, but then didn’t work anymore. I managed to turn the ANR on and off but then it just kept working randomly throughout a song. Not a patch on the EarPod Pros I’m afraid.
Bestwick8
I was using the H3 ANC before these EQ's and had the volume of the H3 just over half on my iPhone and it is way louder than the EQ at max.
I have noticed the odd comments people have made on instagram about all three generations of E8 having too low of volume as well due to B&O not wanting sacrifice sound quality or battery life.
Page 5 of 6 (77 items) « First ... < Previous 2 3 4 5 6 Next > | RSS
