Using Beosystem 5500 on beovision 10 and beolab 6000
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
JamesSamuel
Netherlands
JamesSamuel posted on Thu, Jan 21 2021 10:53 PM
I have connected my Beomaster 5500 with a DIN cable in TAPE2/AUX to the T1611 converter and then the master link cable to my beovision 10 and then the 2 beolab’s 6000 in the beovision. This works perfect music and sounds great.
Only 2 issues.
1: I first have to put on my tv (DTV, or something) to put on the radio. I can’t just press in the radio button on my beo4 remote or master control panel. After i put on the radio the tv goes on black screen, witch is good. But i would like to have it directly with the radio button.
2: I can not change the volume with the master control panel only with the beo4 remote. (I only can use this when i am using my headphone). Maby because it can not communicate with the beovision 10.
Hopefully can someone help me fix this ‘problem’s’, if its even possible.
James
Designed-AV
Sweden
You probably need to have different options settings set.
You will find more info and how to do it at the link below
https://www.beoworld.org/beotech/index.htm
Designed-AV
Sweden
Link >>>>
JamesSamuel
Netherlands
Thanks, i will take a look.
problem 1 fixt itself. Don’t know how but it works now. :-)
JamesSamuel
Netherlands
Page 1 of 1 (5 items) | RSS
