eosound Ouverture
Not Answered This post has 0 verified answers | 3 Replies | 1 Follower
GerriB
GerriB posted on Sun, Jan 17 2021 5:34 PM
Beosound Ouverture System.
Hi I need to remove the bottom back panel of my system so I can get to the lithium battery which needs replacing.
Could I please have some advice of how to remove the panel as I can’t figure it out.
Thank you for your help.
CB
> You are Here <
CB replied on Sun, Jan 17 2021 6:12 PM
Hi
Have a look at this video after 7.50
https://youtu.be/1E3BKTSz9wA
Be aware that the battery is soldered. Removing it is quite simple, but soldering a new one may be dangerous. Instead, you can solder a battery holder in order to use standard battery.
I did that on mine.
Unfortunately, the holder is a little bit thicker than the original battery, so closing the box will be harder...
Important point : once the battery is removed, the factory settings will be lost.
On mine, this introduced an offset in the FM band (about 0.5MHz) —> not a very neat result Sad
GerriB
GerriB replied on Mon, Jan 18 2021 10:21 AM
Thank you so much for your hugely helpful and speedy response. It is much appreciated - thank you again 😊
GerriB
GerriB replied on Mon, Jan 18 2021 10:25 AM
Thank you so much for the incredibly helpful and speedy response to my query. It is hugely appreciated - thanks again 😊
Page 1 of 1 (4 items) | RSS
