LG Compatibility
Not Answered This post has 0 verified answers | 46 Replies | 0 Followers
graham60
graham60 posted on Wed, Jan 13 2021 8:58 PM
I have a Beo4 50" Plasma with Beolab 7.2 and Beo3 +DVBT Module  and use the Beo5 remote, I also have a Humax Freesat and a DVD2 + 8000 & 6000 Speakers
I am "thinking" of upgrading the TV but how is it possible with the limited options on offer from B&O, firstly  I am limited to size 55-60" would be a max as the TV sits in a recess and is mounted on a BV4 50 remote wall bracket,
My second problem is price ! like what is an LG/B&O really worth compared to getting an LG ?
So what I am asking is what would be the best Screen and Sound Bar upgrade to go with, fit in with and be compatible with my system
graham60
graham60 replied on Tue, Jan 19 2021 12:32 PM
That's the part I didn't understand, I wondered what replaced the Beosystem 3, so is the Beo 4 located in the lower screen extension ?, I assume the Speaker "Bar" is just to house the speakers.
Now one really big problem we have with our current set up is the sound, even with the 8000 & 6000 speakers set at low volume when watching even certain TV programs we have to constantly turn the volume up and down, turn it up to hear Vocals and down when the Sound Track comes in, the sound doesn't bother me that much but it drives my wife mad and there's no way to control the vocals without the backing track blasting out, Don't know how the eclipse performs in this department ??
graham60
I'm now getting lost because the Eclipse is now called "second generation", I've seen a "first generation" for sale £6k but B&O don't tell what the difference is, just the same as their information on the product is very sparse.
Puncher
Durham
graham60:
The TV is a bog standard LG so all picture processing is from LG. The b&o speaker bit can down/up mix the audio to your preferred speaker setup - therefore audio only, distinguishing it from either the bs3 or 4.
The volume issue you speak of is a dynamic range thing, most TV's will have a "night listening" mode, or similar, which compresses the audio to limit the difference in volume between the loudest and quietest bits to save you from riding the volume control.
Ban boring signatures!
Puncher
Durham
graham60:
Whereas there were a few custom bits to make the panel fit to the speaker/stand in the mk1, the mk2 is truly a separate LG GX TV which slots onto a b&o made stand/speaker.
graham60
I'd love to know what justifies the £8000 price tag (without w'bracket) And a way round it ??????
Speaper cover Aluminium                          £900
Highest priced LG OLED 55" screen         £1600  Retail to Joe public
Beobuddy
Utrecht, The Netherlands
I think examples are given here.
If you're capable of visiting a dealer, look at both and just ask.
Or you could try buying a GX version and use it for some time and see what you're missing after some time. Maybe a dealer will sell you the soundcenter, mounting plate etc afterwards.
Emil Jensen
Denmark
graham60:
Did you see my post?
I don't think that it is so hard to see.
You get options and much nicer controls and setup with a Eclipse than any other brand.
Off cause this is not cheap when only one brand does it.
I bet you will not find any solution as nice as the Eclipse.
And please read my post again instead of asking the same question.
Emil Jensen
Denmark
Puncher:
The audio engine is the important and expensive bit in a Beosystem 4, else is a tuner and a average HDMI switch.
Also you have the PUC control and everything.
You get a much better TV with a Eclipse than you did with a BV12/11/Avant
Puncher
Durham
Emil Jensen:
Puncher:
Wrong! It was the video processing in the bs3 & bs4 that made a TV into a beovision, otherwise its just a sound centre. The picture of the eclipse may be better than at least some of the models you mention but that is because panel technology has moved on since they were current. The picture of the eclipse could be better, as ably demonstrated by Sony, Panasonic and Philips etc. but B&o have decided not to (or can't afford to) strive for the best picture any more.
The audio engine was not the reason d'etre of a Beosystem.
Mikipidia
What could they possibly improve PQ wise that would be worth the investment?
Eclipse is totally worth it imho
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Puncher
Durham
Mikipidia:
And thats fine, I'm just picking up a point about what a bs3/4 was and wasn't.
graham60
Hi Emil
I think you have answered my question !
Am I correct in saying that the Eclipse (Mk2) is just an LG OLED GX series TV with the 3rd gen. Alpha 9 Processor etc. (all LG & nothing to do with B&O)
And that B&O have added "their" Speaker system /Sound Bar, Their Beo 1 remote control, Their fixings and their Wall Bracket (£800 or £1400 motorise
B&O Eclipse with Aluminium Speaker front (£950) and Motorised Wall Bracket (£1400) £9500
LG OLED 55" GX TV £1600
Millemissen
Flensborg, Denmark
Go nitpicking or go nuts....
What is important here is, that the BV Eclipse/the BV Harmony has the audio part and more, that was built-in to the BeoSystem 4.
Of course there is no need to dwell on the fact, that there is no video processing there anymore.....why should there, the LG is there for that job.
If you want a closer look at these ‘audio functions’, this is a good point to start:
https://www.tonmeister.ca/wordpress/2017/09/15/bo-tech-its-not-just-a-soundbar/
Emil Jensen
Denmark
Puncher:
Emil Jensen:
Puncher:
Hallo Puncher,
I cannot seem to find any info on the video processing in the Beosystem 4, as you seem sure can you find some info on this?
The BV12 was just a Panasonic monitor I am pretty sure that the video processing was done there, and the Beosystem 4 was merely a HDMI switch. Also as you could use the Beosystem for other stuff.
andybandy
Graham60: if you put a list off what you get into the soundcenter of the Eclipse, you would see its worth it. As other tell you her in the soundcenter you get 6 speaker unit with 450 watt power amplifier.
You also get a top surround decoder, puc control (control of 3.parts product with beoremtoe one) , streamer with airplay 2, chromecast audio, tunein and deezer built in. on the 2.gen you will get the information of radio station on the top off the screen and music from chromecast what you play.
You also get the motor control for motorized floor stand and wall bracket for does want to us the motorized stand. So if you again take all this parts and try to buy it seperately in a high quility, my guess is that you will see the price would get close to this £7000. and then you would have many remote controles on the table, and alot off cables and box. Not the same as an beoremote one in your hand.
And seems the 2gen is new designet, and my guess is it will fit the newer LG screen coming later this year also.. =) So you could upgrade your 2020 screen later on. But off course its up to what LG would do in the future.
So go and buy the eclipse TV and you would never regret off that buy :)
And remember we need to support B&O if not we will not have this wonderful B&O product left, and then we can sit her and look in the computer screen and complain why they dont make it :)
Yes, because we complain of higher price and not buy it.
I Know you will love your new BeoVision Eclipse 55 2gen:)
Page 2 of 4 (47 items) < Previous 1 2 3 4 Next > | RSS
