New LG Panels 2021 for Harmony, Eclipse and Contour
Answered (Not Verified) This post has 0 verified answers | 61 Replies | 1 Follower
Emil Jensen
Denmark
Emil Jensen posted on Mon, Jan 11 2021 3:22 PM
Flatpanels
New television now shown at CES,
The G line is now called G1, and come in the same sizes 55/65/77"
It comes with a new brighter EVO panel, for HDR content
The C1 line now comes in a 83" also but nothing new in the panel, only a bit better processor.
So not much new other than the brighter panel, and that is seems that the design is the same, so B&O do not need to change the Harmony, Eclipse and Contour to fit the new panels.
Beovision Harmony 77" 2nd Gen, Beolab 5, Beolab 17, Beosound 1, Beoplay M3, Beoplay H6, Beoplay Earset, Beoliving Intelligence
mbee
Paris, France
ONLINE
mbee replied on Tue, Mar 16 2021 4:30 PM
As already discussed here, B&O does not have the volumes to ask for a specific screen, they will be "forced" to take the G1.
But as there is a chip shortage, I do not expect the new panels to be on time this year (usually around may). I'm waiting for the new LG HU810P/AU810P beamers but they have already been delayed for Europe. I expect the same for TVs.
Mikipidia
The new G1 panel is with in 1 or 2 mm the same as the GX, but as always the webos is different. LG told B&O that for the eclipse v2.
But the chip shortage is a real thing and so is the wait for the software to be apporved
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
moxxey
South West, UK
moxxey replied on Tue, Mar 16 2021 9:57 PM
mbee:
It was similar for the GX launch last year. I picked up one of the first units in to the UK around early May 2020 as I was told there wouldn't be any more for another 3 weeks. Was scarce at launch. C1 will definitely be even harder to get hold of until almost Q3.
JFJBrussels
Any idea of the date G1 panels will be available on Eclipse gen 2 65" in Europe?
Reto
Switzerland
Reto replied on Tue, Mar 23 2021 4:40 PM
Yes, the G1 OLED evo is available both in 65" Eclipse and 65" Harmony. In 77" Harmony, you can also choose the Z9 (or the G1).
Reto
Switzerland
Reto replied on Tue, Mar 23 2021 4:41 PM
The Beonic Man
Bristol
Will B&O make a Harmony to accompany a 55” screen size? I am guessing not but if they did, or do, I am ready to buy one. Anyone know?
BV11-46, BV8-32, V1-32, BS2, P6, A1, H95, E8, BR1, Beo4, Essence
Emil Jensen
Denmark
The Beonic Man:
The Speaker Boxes fit a 65", and the covers can then be 65" or bigger, to fit 77" and 88"
So they would not be able to make a 55" in the current version.
And the sales of bigger screens is the place to be.
So I would guess that it is not going to happen, ever.
If I were you I would consider a 65"
The Beonic Man
Bristol
Thanks Emil. A 65” would just look to large and overpowering in my lounge I think. I could risk it but I think it would be overkill and design and minimalism is far more important to me. You want a home to flow, to work, to have good energy etc; not to be drawn straight to a large dominating tv that takes away from everything else.
Mikipidia
Have a look at one, a 77” even sits ~10cm lower than a bv11-55 sits of the ground when it’s off. When they’re off they’re really not that dominantSmile
The Beonic Man
Bristol
I could do Miki, no harm I guess. My current tv is an 11-46 so how do you think a 65" might compare to that? It's currently right up against the wall on a motorised stand even though I don't turn the stand.
Mikipidia
So a bv11-46 on floorstand sits 108.7 cm of the ground & is 109.7 cm wide
a bv harmony 65'' sits 99.1cm of the ground when off & is 144.9 cm wide
and the bv harmony 77'' sits 115 cm of the ground when off & is 172.2 wide.
It's up to you and your room if that fits or not, I don't know your room. But to me this is the beauty of the harmony in that it's very unobtrusive when it's off even for very large sizes. and the difference between a 65'' screen and a 77'' screen is fairly substantial, it's has ~40% more screen size for only a 16cm higher tv when it's off. (while only being 6cm taller than your bv 11-46 which doesn't change height when on or off)
Measure it I would say and or send a picture so we can see what would and wouldn't work.Smile
mbee
Paris, France
ONLINE
mbee replied on Thu, Mar 25 2021 10:00 PM
Beonic Man, why don’t you just try all the versions at home in augmented reality with the excellent app « B&O Experience » from Bang & Olufsen?
The Beonic Man
Bristol
This is an excellent idea, will do! Thanks for the great suggestion.
The Beonic Man
Bristol
Thanks Miki for your great suggestions.
Page 3 of 5 (62 items) < Previous 1 2 3 4 5 Next > | RSS
