Beogram 1700
Not Answered This post has 0 verified answers | 8 Replies | 1 Follower
jackenhausen
jackenhausen posted on Sun, Jan 10 2021 11:00 PM
Hello,
My Beogram 1700 seems to not have survived a move. Usually, when I push the 45 or 33 button, the arm moves into the correct position automatically. Now it moves towards the turntable, lowers the stylus, and then pulls back into resting position.
I'm not at all familiar with the underlying system that controls the arm and speeds. Any tips about what could be wrong and how I can fix it?
:Thanks,
Dillen
Copenhagen / Denmark
Dillen replied on Mon, Jan 11 2021 6:47 AM
Is there a record on the platter?
jackenhausen
Hi Martin,
Yes there is.
J
Dillen
Dillen replied on Mon, Jan 11 2021 11:35 AM
Is the needle landing on the record or is it falling down just outside of the record?
jackenhausen
Hi Martin,
it does slightly;
The arm moves towards the middle of the platter, stops halfway, then moves back into starting position while lowering the needle...
Dillen
Dillen replied on Mon, Jan 11 2021 3:16 PM
Did you inadvertently push the tracking force setting?
I suggest you check the setting.
jackenhausen
Hi Martin... where do I set check this?
jackenhausen
Hi Martin,
where do I check this setting please?
Thanks,
Dillen
Dillen replied on Fri, Jan 15 2021 10:25 AM
At the counterweight.
See in the user manual / setup guide.
Page 1 of 1 (9 items) | RSS
