Hello Beoworld,
I have a problem with my BeoLab 11 I just got recently. It sounds like air is moving but not the way it should. To me it sounds like both drivers of the BL11 are out of sync.
I uploaded an example at wetransfer. perhaps you could help what the problem could be.
Living room: BeoVision 7 MKV + BeoLab 7-2 + 2x BeoLab 8000 + BeoLab 2 + 2x BeoLab 4000Office / guest room: BV 7-32 MKIV / BL7-1; BeoSound Core + TurntableKitchen: BeoPlay M3Bathroom: Gira Radio + BeoLab CelestialEntrance: BeoPlay M3
Listened to the file and it certainly sounds wrong...
Have no other advice then letting a B&O technician have a look.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Library: A6, Beocom 6000 Bedroom: M5 Office: Beocom 2 Travel: Beoplay E8 2.0, Beoplay P2
I am actually quite amazed that you managed to record such a bass signal from a BL11. Mine supliments my 11-46 and that is it's only role. I can "just" hear a difference. Now I am wondering if there is something wrong with mine? No way a bass note like that!!!!!
Beofile7:I am actually quite amazed that you managed to record such a bass signal from a BL11. Mine supliments my 11-46 and that is it's only role. I can "just" hear a difference. Now I am wondering if there is something wrong with mine? No way a bass note like that!!!!!
Yes every part of it is set to max and it is still hardly audible. As a subwoofer it is pathetic. As an addition to the overall sound it has a value. I previously had a beolab 2. I would rate this at 1/10 of the output?
Damn that thing sounds busted.
BeoLab 18's. Beolab 3's. A8. A9. A2. H7.
I found the problem It seems like one of the drivers is damaged. When I hold the one driver and play music everything sounds smooth and perfect. I think I will repair it myself as a new driver is only 89€ from b&o.
Beofile7:Yes every part of it is set to max and it is still hardly audible. As a subwoofer it is pathetic. As an addition to the overall sound it has a value. I previously had a beolab 2. I would rate this at 1/10 of the output?
BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL17 Black - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence MK2 - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 - H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
