Beocenter 7007 record Player Problems
Not Answered This post has 0 verified answers | 9 Replies | 1 Follower
Joel
Netherlands
Joel posted on Mon, Jan 4 2021 4:58 PM
Like the titles states;
Only 2 things don't work properly on my beocenter 7007.  The remote and the record player.
I don't mind the remote not working.
The record player is a different story.
It starts turning as soon as the unit gets power. Don't have to turn on anything. It turns indefinitely until I unplug it from the mains.
It does detect records because when I push the PH button when there's no record on it, it shows the UUUU message. Pushing the STOP button doesn't do anything. And also the mmc will never be lowered on to the record. Even when I'm telling it to by moving it above the record and pushing PH.
When I push it down myself I can hear the music.
I hope someone can help me.
Dillen
Copenhagen / Denmark
What happens if you (while the deck is running) move the tonearm by hand to where the lead-out groove would be on a record - will it fall back in correct sequence?
It could also be that someone, with the best of intentions, lubricated the cam wheel and the small actuator arms operating there.
That's a definite DON'T.
You can lubricate the wheel center and the grooves in the wheel where metal arms are running, but the small actuator arms MUST "rattle around" clean and dry.
This goes for all Beogram and Beocenters with this type of cam wheel.
Joel
Netherlands
Joel replied on Mon, Jan 4 2021 9:25 PM
Thanks Martin. Unfortunately the arm will not fall. Tried different record sizes
Dillen
Cartridge fitted?
Tracking force correctly set?
Joel
Netherlands
Joel replied on Tue, Jan 5 2021 10:33 AM
I have the mmc4.
If the tracking force means the counterweight then, I don't know. Because the boom doesn't drop down onto the record.
I've stacked a few records on top of each other to see if the audio works and that works just fine, although the boom resists to move inwards with the record.
Dillen
Dillen replied on Tue, Jan 5 2021 10:56 AM
You will have to set the tracking force.
If it's set to zero now, the tonearm will not lower.
Set it to 1.4g or 1.5g for MMC4.
Joel
Netherlands
Joel replied on Tue, Jan 5 2021 11:30 AM
I see what you mean. I did that, but there's a small bracket/arm holding the boom up, so it'll never drop down. I don't know if that is to mechanically move out of the way?
Dillen
The small fork-like arm is what lifts and lowers the tonearm.
Joel
Netherlands
Joel replied on Tue, Jan 5 2021 2:06 PM
Thanks! Then we've found the problem. Because that thing doesn't do anything and is completely loose. It isn't connected to anything anymore :-(
Think I'll start looking for a donor 7007. Or are these easily sourced parts?
Dillen
Depends on which part(s) is/are needed.
Page 1 of 1 (10 items) | RSS
