Beogram 4000 malfunction after shipment
Not Answered This post has 0 verified answers | 65 Replies | 2 Followers
T4000
Gothenburg, Sweden
Silver Member
T4000 posted on Fri, Nov 20 2020 6:02 PM
Hi!
I have a Beogram 4000 that was damaged in shipment. It was well maintained prior shipment. I initially posted here: https://forum.beoworld.org/forums/t/44481.aspx, but got recommended by sonavor to start a thread here instead.
The [numbers] refers to the Service manual. More pictures and clips can be added upon request.
Mechanical issues found (but now corrected):
a)       The Slide was loose and tilted and the Detection arm was relocated towards the Tone arm (see picture IMG_3629.JPG).
b)      Pulley [124] came loose during transport and has likely been rattling around freely inside the Beogram. (in this Beogram replaced by a metal version, see picture IMG_3630.JPG). It was found again under the Turntable [4]. The loose Pulley resulted in the free moving Slide.
c)       The Slide threaded rod (Spindle [224]) was hanging loose-ish, also an effect of the loose Pulley.
d)      One of the Slide Contact pins and its plastic holder (Switch E, SO - Switch off/Home position) were knocked off.
Functional issues found (please note that issue #5 is now permanent and overrules the other 4 issues):
1.       Tone arm lowering even if no record is present. Intermittent problem. Happened both on 7" and 12" position. The detector arm bulb is lit up, but something is wrong in the sensor circuits.
2.       Another intermittent problem: sometimes the detection arm function works when scanning an empty platter, but then when the Slide are reaching end position, the servo motor continues to push the Slide to the center. OFF has to be pressed to return.
3.       The Slide stopped over the 12" position, then slowly moving towards the center, then returning back home. This occurred both with and without record. Don't know if this is a normal operation, but it happens intermittently.
4.       When playing a record, the arm lowers, but after 1s the servomotor starts and the arm moves across the record for about 0.5-1cm (my poor Pink Floyd album).
5.       After that I started (in pure frustration) to adjust mechanical bits and pieces according to the service manual. When I came to the step of Tracking force adjustment, I started ON, then pressed Reverse (>) to move the tone arm away from the platter. When I did this, the Slide decided to return to home position. I pressed ON again to repeat the procedure, but the Slide moved ~1 cm, then returning home again (see https://youtu.be/HG-VJ3dCZc0). https I tried a couple of times, but always the same. Also tried to manually push the Slide Contacts, but no reaction. I might have smelled burned electronics, probably for the main PCBA, but I'm not sure on this. The main PCBA [PC 8009012] were inspected visually, no remarks.
Initially I could really need some advice on issue #5, as the other issues can not be reproduced as long as #5 occurs.
Thanks a lot in advance.
sonavor
Texas, United States
sonavor replied on Tue, Nov 24 2020 10:21 PM
T4000:
Observation: When I was done with the test above (Slide at position [ D ], I placed the servo belt on the pulley again. When connecting the power and pressed "ON", the Slide return to home position. Same as before, regardless of previous position on the platter.
Per
Hi Per,
I opened up one of my Beogram 4000 turntables and ran a couple of tests.
When I press "On" and the Beogram starts to move the arm assembly forward I can use the "<"/">" to stop and position the arm.
After stopping the arm over the area of record play I unplugged the Beogram.
Next, I plugged the Beogram back in to power.
Like yours the Beogram remains in the "Off" state.
Unlike yours however, when I press "On" my BG4000 knows where it is and continues forward to the first record set down spot it finds. It does not return home.
I also checked this out on a second Beogram 4000 and get the same result.
So it appears your Beogram 4000 has a blocking signal from somewhere in the control logic.
There is a nice BG4000 Training Notes manual in the Beoworld service manual section that details the control logic of the Beogram 4000.
I recommend getting it. You need to have a Beoworld Silver membership or higher to access it.
I will read through it myself to see if I can get some hint on what to check next.
Maybe someone else on the forum will have an idea as well.
-sonavor
sonavor
sonavor replied on Tue, Nov 24 2020 11:06 PM
One more quick thought...it occurred to me that your Beogram 4000 symptoms are like the logic for the "Off" button is always engaged.
-sonavor
sonavor
Yet one more possibility :-)  ...
After talking to Rudy he suggested that it might be a problem with the ">>" button/signal from the control panel.
-sonavor
T4000
Gothenburg, Sweden
Silver Member
T4000 replied on Wed, Nov 25 2020 9:18 PM
Hi sonavor and Rudy,
Tonight, I opened up the control panel to measure the button switches. They are all according to spec. I paid extra attention to >> and OFF, but no remarks. Did not have time to clean them from potential oxide today, but might revisit for that.
I also visually insected the electronics of the two PCBA. No remarks.
Per
sonavor
Okay, I was hoping something would be revealed there.
I think there still has to be a problem where the Beogram control logic is being told there is an end stop (ES) event or a fast reverse (>>) event.
Please download the Beogram 4000 training notes from the Beoworld technical information page. You will need to get familiar with the control signals.
-sonavor
T4000
Gothenburg, Sweden
Silver Member
T4000 replied on Sat, Nov 28 2020 5:51 PM
Hi sonavor,
Today I finally had some time to look at the logic circuits described in Service Manual, section 3-1, Diagram 1. I focused on the ES and OFF signals. Those signals feed into the NAND gates in 3IC0, 3IC1 and 3IC2. After pressing ON, I measured as follows:
  • 3IC0, Pin 10 (ES in): 2,6V
  • 3IC0, Pin 11 (OFF in): 2,6V
  • 3IC0, Pin 1 (NAND out): 0V
  • 3IC1, Pin 10 (OFF in): 2,6V
  • 3IC1, Pin 11 (ES in): 2,6V
  • 3IC1, Pin 1 (NAND out): 5,6V
  • 3IC2, Pin 3 (OFF in): 2,6V
  • 3IC2, Pin 4 (ES in): 2,6V
  • 3IC2, Pin 8 (NAND out): 0V
Is looks like 3IC1 is defective.
What does the jury say?
Per
sonavor
On those NAND logic devices it only takes one input to be a logic "0" in order for the output to be a logic "1".
3IC1, Pin 1 has a 1.2KOhm pullup to +6V so it appears to me that one of its inputs must be a logic "0".  So 5.6V would be reasonable for the output.
Those NAND logic devices do not fail very often and should it turn out you do have a failed NAND device it would bring into question whether you Beogram was a working unit prior to shipping. It seems unlikely the shipping event would have damaged a none moving part like that.
While strange things are possible I think it is more likely that your fault is in something that sends voltage signals to the logic controls.
The question to check is what should 3IC1, Pin 1 be when you press "On".
According to the Beogram 4000 Design Notes I pointed you to 3IC1 is the logic for the tonearm Lift so I don't believe it is a problem here.
Check the 3IC0 logic device and the flow diagram in section 5-4 of the service manual.
According to the Design Notes, 3IC0: Automatic Slide Transport In, is the logic device that starts the Beogram. Monitor the SI signal that starts things off.
-sonavor
sonavor
sonavor replied on Sat, Nov 28 2020 10:37 PM
This diagram shows the logic board and which logic gates relate to what Beogram 4000 functions.
T4000
Gothenburg, Sweden
Silver Member
T4000 replied on Mon, Nov 30 2020 7:47 PM
Hi sonavor,
Regarding the logics:
I have now read the document you recommended, BG4000 Training Notes manual. I will leave 3IC1 be for now. I focused on section 3-25 (3IC0). I measured the voltage of pins, but I'm a bit hesitant to draw any conclusions anymore, so I'll just present the results below. As you also pointed out the Fault-finding diagram 5-4 in the Service Manual, I'll present the measurements for these signals as well.
IC0
Pin                     Function           Voltage (V)
1/2                     NAND (/Q0)       0.06
5                         SI                        5.85
7                         +6V                    5.85
8/9                     NAND                5.75
10                      ES                       1.93                           (a bit lower this time, 2.6V last time I measured)
11                      OFF                    1.93                           (a bit lower this time, 2.6V last time I measured)
12                      /Q1                    5.57
13                      Input fr.3IC9      2.32
IC1
5                         WO                    5.8
13                      "Is SI missing"    0.77
IC7
2                         DR                      5.87
5                         BL                       5.88
The detector arm light = On
Regarding SI:
I studied the Start Impulse (section 3-11 in the Training Notes manual). I don't have an oscilloscope at hand, so I'm not quite sure I can observe the 10ms pulse we are talking about here. I can buy one if needed. Can transistor 1TR20, that generates the SI, give some hints? Any ideas what to look for in that case?
Regarding what happened during transport:
As far as I was told, the Beogram was in good shape prior shipment. Please note though: issue #5 was not present when I received the Beogram. That error appeared a couple of days later. The "only" failures the first week after arrival was issue #1 -> #4:
4.       When playing a record, the arm lowers, but after 1s the servomotor starts and the arm moves across (and scratches) the record for about 0.5-1cm.
I'll try to describe (and remember) exactly what was going on when #5 first appeared:
I was moving the Slide from Position [ D ], first groove of the record, slowly to the right pressing ">" with several, short intervals. (Purpose: to get the stylus over the aluminum plate for tone arm weight check). I pressed ">" a few times, and then the issue #5 appeared, causing the Beogram to switch off. After that I removed the Slide Contact Spring assembly to reach the Slide Contacts. I pressed the contact pins, probably from the right to the left, and then I might have smelled burned electronics.
Per
sonavor
sonavor replied on Mon, Nov 30 2020 11:37 PM
Just looking at your IC0 logic -
IC0
1/2                     NAND (/Q0)       0.06
5                         SI                        5.85
7                         +6V                    5.85
8/9                     NAND                5.75
12                      /Q1                    5.57
If my memory serves me correctly...
Your Beogram 4000 appears to be in the "On" state according to the IC0 flip-flop pins 1 & 2 state.
The IC0 flip-flop circuit is latched where
/Q0 is a logic "0" (or "L").
Maybe someone else who has gone through this recently can confirm.
So it appears that your IC0 logic is saying the Beogram is on and can move the arm transport forward.
Since that isn't occurring then something else must be stopping the tangential arm assembly.
When you are in this state do you see the platter motor pulley turning? Can you feel the tangential arm assembly motor turning (or trying to turn?).
You mentioned that the spindle and spindle pulley had come off earlier.
In re-assembling that are you sure the spindle is correctly positioned now?
See if you can manually turn the pulley and move the tangential arm assembly with the servo belt removed. Is it easy to move or do you feel a lot of resistance?
-sonavor
sonavor
I decided to go over the Beogram 4000 control circuit to refresh my memory.
The logic "Low" ("0") on the  /Q0 signal that comes from the 3IC0 flip-flop circuit, will turn on 1TR25 to drive the tangential arm assembly (the slide assembly) forward. The same control over 1TR25 occurs with the "FF" control panel button is pressed.
So mechanically, check the spindle movement that drives the slide and make sure it moves correctly. As I mentioned earlier, you can test it manually by disconnecting the servo pulley belt and turning it by hand.
Electrically, measure the DC voltages around 1TR25 and see what they are when the
 /Q0 is a logic "0".
-sonavor
T4000
Gothenburg, Sweden
Silver Member
T4000 replied on Tue, Dec 1 2020 5:46 PM
Hi sonavor,
Today when I started up the Beogram, Error #5 was gone. I decided to screw the spring assembly back in place, but then Error 5 reappear. And disappear. Error #2 and #3 could be reproduced when #5 was gone (caught #3 on tape: https://youtu.be/4FmXFWzZDfk). And I might have a new issue. Error 6, the tone arm seems to be stiff, it doesn't lower (this stiffness can also be seen in the Error #3 video). And then.... Error 7, I broke this plastic construction:
The below text was written before the Beogram (and I) went all erratic (I never got to measure 1TR25, let me know if it still makes sense):
There is nothing mechanically stopping the Slide. I can however not electrically run it forward due to error #5. When I remove the servo belt and manually turn the pulley it runs smoothly. The manually turn the pulley is what I have been doing so far to move the Slide for the various tests/adjustments.
The Slide servo motor is running when the Slide is returning home. The Slide moves back home at ON. If it is already at home, it moves 0.5cm to the left, then back home and turns off. Error #5.
Platter motor is running.
My logic circuit measurements in previous posts were made with the servo belt removed, otherwise I would not have time to measure before it tuns off again. So, my measurements are under that condition; Slide moving back home (I stop the condition by manually pressing SO).
Regarding the spindle
The Slide Spindle seems move as intended, and I also confirmed the alignment seems to be according to Service Manual 4-6 "Adjustment of Spindle". See also video the Spindle when Slide is returning home: https://youtu.be/53YIdLNQb6g
New observation:
This PCBA seems bent (red) and the conductor (blue) seems to be damaged. I think I read something about this (blue) being normal when the trim pot was installed, though.
Per
sonavor
Hi Per,
It is a little confusing regarding the exact status of the Beogram 4000.
If I read your post correctly you are saying the "Error #5" (where the Beogram won't start) is now intermittent, right.
Regarding your video of the Beogram 4000 starting, stopping at the first set down point, then continuing on to the end stop....
That looks normal to me. The tonearm will not actually drop if there is no cartridge mounted. It requires some weight to go with the arm balancing to drop freely.
When the Beogram continued forward to the end stop did you click FF to cause that to happen or did it do that on its own?
-sonavor
T4000
Gothenburg, Sweden
Silver Member
T4000 replied on Tue, Dec 1 2020 7:08 PM
That makes us 2.
Error #5 is now intermittent, yes. Sadly.
The tone arm is not balancing anymore, it is stiff, regarless of solenoid position (error #6). Somethign might have happened when I reinstalled the cover a few days ago.
In the Video I only pressed ON, the rest was done by the danes.
Per
sonavor
Okay, then what must be happening with the Beogram travel across is the result of the tangential tracking sensor being out of alignment.
That would make sense based on the Beogram components that were out of place when you received the Beogram shipment.
What is happening there is most likely the Beogram sensors are telling it that the arm is free and should be playing a record.
The tangential arm sensor thinks the arm is not in the correct tracking position so it instructs the servo motor to advance it forward to catch up.
It never catches up because the sensor is out of alignment so it just continues forward until it hits the end stop.
We don't need to mess with that just yet but will obviously have to come back to it soon.
The good thing is that a portion of the tangential arm control logic appears to be working fine :-).
For the stuck tonearm you need to carefully observe the tonearm movement mechanics.
If the arm does not freely move when the arm lowering lever allows it to drop then there has to be some physical thing blocking it.
First try it with the Beogram unplugged.
Manually move the lever that the solenoid would engage to release the arm lowering damper and watch the arm lowering lever action.
Checkout how the lever is engaging and disengaging with the horizontal bar that releases the tonearm itself.
Is there contact?
Is the arm lowering damper working?
Make sure the arm lowering limiting screw isn't preventing the lowering.
Did someone move the tonearm counterweight too close to the tonearm base so it won't pivot down?
Like I said, there has to be something mechanical there causing a problem and the mechanical components are all right there at the back of the tonearm.
-sonavor
Page 2 of 5 (66 items) < Previous 1 2 3 4 5 Next > | RSS
