Cabling through wall for floor standing TVs
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
Michael
Sweden
Michael posted on Tue, Nov 10 2020 5:04 PM
Hello,
Has anyone here drilled a hole through the wall behind a floorstanding beovision? I am curious about a way to hide cables all together, so Im considering drilling a hole high enough so that the cables cant be seen below the TV. Not sure though if this can be done in a way that looks good from the sides as well is practical.
This is in regards to an Eclipse gen 2.
YannChris
Larmor Plage - France
Hello,
Another way of hiding cables.
I had an aluminum plate cut at a DIY store and glued two brackets to it.
All cables run in the "sock" which passes behind the plate by a triangular cut at the bottom of the plate.
Then, the cables run through the wall and floor and arrive in a cabinet a the basement level where the other sources are placed.
Regards,
Yann.
