Beocord 3500 - tape deck alignment - help needed
Not Answered This post has 0 verified answers | 7 Replies | 1 Follower
mpc
mpc posted on Mon, Nov 9 2020 5:24 PM
Hi All
Hope I'm posting this in the right area.
I've replaced the belts on a Beocord 3500 but now the rotating head does not seem to be activated by anything so is free to rotate and jam the deck. I think I've replaced the main flat belt correctly but because it was basically a liquid I had to guess the correct path (with the 2 capstans at the bottom I've routed the belt around the outside of the left one then over the outside of the black cog at the top then around the motor pulley and back through the center of the 2 capstans).
Could some please advise if there is a correct alignment and what actually rotates the head ?
Is there a tape deck service manual available ?
TIA
MPC
lawrencejmcook
What about the Erwin who sold you the belts? Didn’t they provide instructions?
If not, perhaps you could ask them to advise how to correctly fit them.
Dillen
Copenhagen / Denmark
ONLINE
Dillen replied on Tue, Nov 10 2020 6:28 AM
Has the spring at the back of the tapehead, that makes it snap into position, fallen off?
mpc
mpc replied on Tue, Nov 10 2020 6:51 AM
Hi
I think your right - there is no spring on the tape head.
Can you advise what type of spring this should be and where it anchors to at both end please?
TIA (again)
MPC
mpc
mpc replied on Tue, Nov 10 2020 6:54 AM
Hi
I think after experimentation the belts are right as FF and REW work  - play loads the heads but they are misaligned preventing the spools rotating.
Believe there is a missing spring on tape head gear as suggested by Dillen.
Looking for advise as to what and where this spring goes please.
Regards
MPC
mpc
mpc replied on Wed, Nov 11 2020 6:51 AM
Hi
Would anyone have a photo that includes the back of the tape head showing the rotating gear and spring please (version 2 tape deck I believe)?
MPC
RafH
Silver Member
RafH replied on Thu, Dec 17 2020 7:22 PM
mpc
mpc replied on Fri, Dec 18 2020 10:33 AM
Hi
Thank you for the picture - I'll see if I can make a similar spring.
Regards
M C
Page 1 of 1 (8 items) | RSS
