beovox ms 150 speakers
Answered (Verified) This post has 16 verified answers | 51 Replies | 1 Follower
marc
s. wales uk
marc posted on Mon, Jan 21 2013 3:07 PM
Hi All
Could someone please tell if ms 150 speakers are soild wood or veneer as i'm picking a pair up next week which has a small chip out of cabinet which i have not seen and need to know best way to repair.
marc
Dillen
Copenhagen / Denmark
ONLINE
Answered (Verified) Dillen replied on Mon, Jan 21 2013 3:42 PM
Verified by marc
They are all particle board.
Wooden cabinets have veneer added, white cabinets have foil.
Dennis
Denmark
Answered (Verified) Dennis replied on Mon, Jan 21 2013 3:46 PM
Verified by marc
Veneer. Smile
Fantastic speakers btw.! Be aware, that they most likely suffer from foam rot if they haven't been refurbished. But be sure, that they come with the original drivers no matter what, otherwise they are worthless.
They are definitely worth refurbishing if 100% original. They are the best passive speakers made by Bang & Olufsen - And that says a lot!
Feel free to ask, if you have more questions - I've owned a pair of MS 150s and have a pair of almost mint MS 150.2s now. Cool
- Dennis Smile
Søren Hammer
Denmark
Verified by marc
The stands are definitely needed as the bass reflex port shouldn't touch the floor. M150 stands should fit the MS150 - I am almost sure that B&O only made two sizes. £250 sounds fine if they are as you described and with stands.
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
Dennis
Denmark
Answered (Verified) Dennis replied on Mon, Jan 21 2013 7:27 PM
Verified by marc
I think the price is fair - I sold my MS 150s for 225£ a few years ago and I realized afterwards that I probably could have sold them for 325£. They were refoamed and in good condition. Bad luck, but I have a lovely pair of MS 150.2s now which have been refoamed and fitted with new caps in the crossovers - I won't part with these unless someone offers me a very attractive amount of money for them or I find a white pair which are rare as hens teeth!
The stands for M 150 and MS 150 are identical. Smile
- Dennis
Peter
Earsdon
Answered (Verified) Peter replied on Mon, Jan 21 2013 10:13 PM
Verified by marc
Yes - MS150s are probably the best passive speaker B&O made. The carcass actually included a bitumen layer which deadened the resonance more. I always found these a contrary speaker though - the design is clearly superb and the sound quality fantastic with a frequency response curve only bettered by Beolab 5s; but aspects of construction are very poor - it is as if the bean counters have gone through an original design shaving pennies off - the frets are very flimsy, the foam surrounds rot and the bass ports appear to be made from carpet roll tubing! The internal finish is also far poorer than the earlier M100s. All bits you cannot really see, but prior to this, B&O were always very good at these bits as well! Look inside a Beolab 5000 amplifier and is a a piece of art.
Peter
Cleviebaby
Exeter, United Kingdom
ONLINE
Verified by marc
Mark,
The BM 4400 is arguably the finest sounding Beomaster and should drive MS 150s without any difficulty. To find a mint and boxed example is very unusual - well done.
I have always regretted not buying the MS 150s when I had the chance, even though they would have been incompatible with my listening room.
Cleve
Dillen
ONLINE
Answered (Verified) Dillen replied on Tue, Jan 22 2013 6:11 PM
Verified by marc
Dennis:
- Dennis
Do you have any printed information to back this up ?
If I remember correctly, the MS150 stands are both deeper and wider than the M150 stands to
match the equally wider and deeper cabinets of the MS150.
There are at least 8 different speaker stands with the square foot. Probably more.
 (Not counting the modifications introduced to the speaker mounting screws/washers and
tilting screw on december 30th 1981).
square4
Verified by marc
The stands for m 150 is 29x32cm and 57 cm high.The stands for ms 150 is 30x36cm and 63c high.
So Martin is absolutely right about this.
Henrik
Dennis
Denmark
Answered (Verified) Dennis replied on Tue, Jan 22 2013 6:34 PM
Verified by marc
Ok, I stand corrected on that one. Embarrassed
I always imagined, that the only difference in dimension between the M150 ans MS150 was the height.
But they will fit! - The mounting holes are placed at the same width (At least that's the case with my MC120.2 and MS150.2 stands), and if you can't find the widest stands and the alternative would be to use the MS150s without stands, then I would go for the M150 stands if they can be bought for a reasonable price.
I think I have a pair of the biggest stands in rough condition somewhere, but they weigh half a ton, so I guess they would be quite expensive to ship... Where are you located, Marc?
- Dennis
Cleviebaby
ONLINE
Verified by marc
Marc,
If it is truly 'mint' cosmetically and is fully working, then you have a bargain. The box alone would have added £20-£40 to its value.
Cleve
valve1
The south of France and occasionally Dublin Ireland
Answered (Verified) valve1 replied on Wed, Jan 23 2013 7:44 AM
Verified by marc
In mint condition with boxes etc it was a good deal even if it needs some fixing.
Have you powered it up yet ?
You could cut your losses...... give you 50£ !  :-)
Peter
Earsdon
Answered (Verified) Peter replied on Wed, Jan 23 2013 8:55 AM
Verified by marc
If working perfectly, go for £250 and see if you get some bites!
Peter
valve1
Answered (Verified) valve1 replied on Wed, Jan 23 2013 2:29 PM
Verified by marc
mdm123:
The price you gave, was it for beocentre 3600
Mark I think there is some confusion, Peter and I are talking about (lusting) your 4400.
Søren Mexico
Mexico City
Verified by marc
mdm123:
4400 paper work. Can anyone tell  me how to make my pics smaller they keep getting cut once i upload
Use a photo editor, make your pics 800 pixels wide before posting. And your pics are not cut, click on them and they open in the full size.
Søren Mexico
Mexico City
Verified by marc
Just amazing when it works without problems, a very nice BM 4400, I´m working on one at the moment, but with a lot of problems. Congrats
Dennis
Denmark
Answered (Verified) Dennis replied on Wed, Jan 23 2013 11:54 PM
Verified by marc
mdm123:
i'm in south wales-united kingdom, how much you selling your ms150 stands
I just checked, and they are unfortunately the smaller ones for M150. They would also need a layer of paint to look good again, so I think you would be better off, if you wait and find a pair of MS150 stands - I sadly think you should be pretty lucky however... so if you don't find any, then send me a PM. They are better than nothing...
You could also attempt to make some yourself. Stick out tongue
- Dennis
marc
s. wales uk
Also would anyone be interested in a beocenter 3600 with mmc 3000 all boxed with manual etc, in working order, it does make crackly sound when tuning radio but once locked on its fine and one of the perspex sliders are missing.
marc
Dillen
ONLINE
Dillen replied on Tue, Jan 22 2013 7:58 PM
Of course, you have both, Henrik.
I am getting old ...  Laughing
Thanks for clarifying this, Henrik.  Yes - thumbs up
marc
s. wales uk
pics of mmc 3000 that go's with beocenter 3600
marc
marc
s. wales uk
Here's  some pics of beomaster 4400 i picked this week mint condition and boxed
marc
marc
s. wales uk
beomaster 4400 box etc
valve1
valve1 replied on Tue, Jan 22 2013 11:22 PM
Great getting in such nice condition. Its one of my most used Beomasters - I am sure you will enjoy it,
marc
s. wales uk
marc replied on Tue, Jan 22 2013 11:38 PM
I paid £100 for it, was this a good deal or have i paid to much, not that it matters to much to me i intend to keep it but it would be nice to know  that i had it within its true value
marc
Cleviebaby
ONLINE
Verified by marc
Marc,
Cleve
chartz
Burgundy, France
chartz replied on Wed, Jan 23 2013 6:37 AM
mdm123:
marc
Is it for sale or are you giving it away Marc?
Jacques
valve1
Verified by marc
marc
s. wales uk
marc replied on Wed, Jan 23 2013 8:10 AM
yes all powered up and i connected to a pair of m70's, if my ears are telling me the truth it is sounding better than my beolab 5000,beomaster 5000 and 5000 mk1 setup.
marc
marc
s. wales uk
marc replied on Wed, Jan 23 2013 8:13 AM
I think i will end up putting it on ebay but no clue on its value
marc
Peter
Earsdon
Verified by marc
Peter
marc
s. wales uk
marc replied on Wed, Jan 23 2013 11:14 AM
Marc
valve1
Verified by marc
mdm123:
Page 2 of 4 (52 items) < Previous 1 2 3 4 Next > | RSS
