http://archivedforum.beoworld.org/forums/t/311.aspx?PageIndex=1
Så starter vi tråden på ny. Vil du se den gamle tråd, tryk på link herover.
Hej
Ja så kan vi starte forfra her på det nye BeoWorld. Min hobby gennem mange år er Bang & Olufsens produkter. Det startede i sin tid med en Beomaster 4400. Siden har det udviklet sig.
BeoVision 7-40" LCD HD Digital Surround Sound TV og ICEpower fra B&O er kun en del af hvad jeg har tænkt mig med denne tråd. Nyheder og et forsøg på at hjælpe jer med evt. B&O problemer i sprog og med tegninger så alle kan følge med. Jeg tager forbehold for eventuelle skrive-, og stavefejl såvel som grammatiskefejl.
Med venlig hilsen
Ja, det kan man mene om, hvad man vil.
Man kunne jo også vente med at mene noget indtil man har suppleret ‘ens mening om hardwaren’ indtil man har suppleret med egne lytteoplevelser.
Her er et citat - sikkert fra samme artikel som Peter Pan citerer fra....det var åbenbart ikke vigtigt for ham at nogle allerede har hørt og har en mening derefter:
’But the Beovision Harmony will live or die by its sound. A few caveats here to our test: Bang & Olufsen is still fine-tuning the speakers, hence a finished product won’t be available until the autumn, and the gallery space we heard it in was rather noisy and with hard walls and large windows not particularly conducive to great sound.
That said, we can certainly confirm B&O has been able to come through on its promises of power. Though exceptionally taut bass was never really going to be on the agenda in a setting such as the one we were in, the Harmony digs deep and deals its blows with venom; you could be fooled into thinking there was a dedicated subwoofer at play.
Musically, things seemed to hang well together as well. We were treated to excerpts from The Greatest Showman and Bohemian Rhapsody, both of which sounded pretty well judged in terms of timing and dynamics – which as we well know is no easy feat.’.
Kunne du ikke - for en god ordens skyld - angive kilde eller link, når du citerer.
Double post
Peter Pan: IKEA Harmomy. Nemt at pakke sammen for opbevaring.
Not that I'm fond of intellectual rights but it does discredit all you previous 'tips and tricks"
Peter Pan: Ide ari , men denne tegning er min.
If you say so…
