Beogram 7000 muting question
Not Answered This post has 0 verified answers | 2 Replies | 1 Follower
Filip
Copenhagen, *Denmark
Filip posted on Fri, Oct 30 2020 10:48 AM
Hey - I finally got my MMC2 for my Beogram 7000 retipped and the sound is again as it should be.
However, I notice that when the tone arm is lifted in the middle of the song, it mutes the left channel a little before the right channel - this should happen at the same time, right? Also when the tone arm is set down in the middle of a song, there is also a muting delay for half a second on the left channel. Is this adjustable somewhere?
Dillen
Copenhagen / Denmark
Dillen replied on Fri, Oct 30 2020 12:01 PM
It's all inside a mechanical switch with two contacts.
You can replace the switch but I doubt you will find one that activates both contacts absolutely simultaneously.
Filip
Filip replied on Mon, Nov 2 2020 4:25 PM
Thanks for the answer - then that is one less thing to worry about :)
Page 1 of 1 (3 items) | RSS
