Bang & Olufsen app won't stream music files
Not Answered This post has 0 verified answers | 17 Replies | 1 Follower
Antonius Robin Iriawan
Jakarta, Indonesia
Antonius Robin Iriawan posted on Wed, Oct 21 2020 3:53 PM
Dear Beoworlders,
I usually play music through the Bang & Olufsen app and stream it to my speaker.
Now, I can't play my music anymore.
Strangely, Airplay works well and TuneIn Radio within the Bang & Olufsen app seems to be working as well. Only when I want to play my music from the music app, it does not work.
Below are my questions:
1. The files are now AIFF. Does this make my speaker unable to play music? Does anyone have any experience with AIFF file?
2. I reset my product and reinstalled the Bang & Olufsen app. And it did not solve my issue. Am I missing something here?
I hope Beoworld can help me deal with this problem. Thank you
Best Regards, Mit freundlichen Grüßen, 올림
Antonius Robin Iriawan, 로빈
Beosound 35 and Beoplay H5
Jaffrey2230
Washington DC
Silver Member
I have 6 B&O streaming speakers. Music from the B&O App plays from my iTunes library and works flawlessly. I usually pick a playlist and play it. I am using the beta version of the app. I can control from 2 Essence remotes connected to 2 Cores (rarely), 2 iPhones purposed exclusively to be Beoremotes (i.e. runs B&O App along with my streaming services) as well as my iPhone and iPad Pro Big Smile
No issues for me. So could be music file format...don't know.
My B&O Home:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beoplay M5 (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • Beoremote X (better than Eclipse and Halo Big Smile)
Jakarta, Indonesia
Jaffrey2230:
Thank you for your reply.
May I know what file type you are using?
Jakarta, Indonesia
Jaffrey2230:
Thank yoiu for your reply.
Carolpa
Antonius Robin Iriawan:
Dear Beoworlders, I usually play music through the Bang & Olufsen app and stream it to my speaker. Now, I can't play my music anymore.
2. I reset my product and reinstalled the Bang & Olufsen app. And it did not solve my issue. Am I missing something here? I hope Beoworld can help me deal with this problem. Thank you
Best Regards, Mit freundlichen Grüßen, 올림 Antonius Robin Iriawan, 로빈
what are the resolution and bitrate of the aiff files?
Note: Airplay works max 48kHz and 24bit; Core compatible
The app is a controller, so the fault as discibed doesn’t originate in the app.
mbolo01
Annecy - France
Carolpa:
When streaming from the B&O App, the device acts as a DLNA server, Airplay is not used here. For the purpose of helping the OP, I converted an ALAC file (24/96k) to a 24 bits / 96,000 kHz AIF file, played it against a M3 and I had no issue.
@Antonius Robin Iriawan:
- have you recently installed something new on your device? Something that could conflict with the TCP port used for the DLNA service, 8085 here.
- are your AIFF files higher than 96,000 kHz?
Below is the M3 notification while playing:
{"notification":{"timestamp":"2020-10-22T07:55:07.563396",
"type":"SOURCE","kind":"source","data":{"primary":"music:2730.1200316.28725910@products.bang-olufsen.com",
"primaryJid":"2730.1200316.28725910@products.bang-olufsen.com",
"primaryExperience":{"source":{"id":"music:2730.1200316.28725910@products.bang-olufsen.com",
"friendlyName":"Music","sourceType":{"type":"MUSIC"},"category":"MUSIC","inUse":true,"profile":"","linkable":true,
"recommendedIrMapping":[{"format":0,"unit":0,"command":145},{"format":11,"unit":0,"command":145},{"format":11,"unit":0,"command":148},
{"format":0,"unit":0,"command":150}],"contentProtection":{"schemeList":["PROPRIETARY"]},
"embeddedBinary":{"schemeList":[]},"product":{"jid":"2730.1200316.28725910@products.bang-olufsen.com",
"friendlyName":"M3"}},"listener":["2730.1200316.28725910@products.bang-olufsen.com"],"lastUsed":"2020-10-22T07:52:24.220000",
"state":"play","_capabilities":{"supportedNotifications":[{"type":"SOURCE","kind":"source"},
{"type":"SOURCE_EXPERIENCE_CHANGED","kind":"source"},{"type":"PLAY_QUEUE_CHANGED","kind":"playing"},
{"type":"NOW_PLAYING_ENDED","kind":"playing"},{"type":"STREAMING_STATUS","kind":"streaming"},
{"type":"PROGRESS_INFORMATION","kind":"playing"},{"type":"NOW_PLAYING_STORED_MUSIC","kind":"playing"}]}}}}}
{"notification":{"timestamp":"2020-10-22T07:55:07.564458","type":"NOW_PLAYING_STORED_MUSIC","kind":"playing",
"data":{"name":"Space Oddity","duration":320,"trackImage":[{"url":"http://<iphone IP address>:8085/media/artwork/3704425888912782282","size":"large",
"mediatype":"image/jpg"}],"artist":"David Bowie","artistImage":[],"album":"","albumImage":[],"genre":"","originalSource":"DLNA",
"playQueueItemId":"plid-1481"}}}
Carolpa
Carolpa replied on Thu, Oct 22 2020 11:45 AM
mbolo01:
Carolpa:
I would say when using the "Music" source the app is a DLNA controller. For streaming services it seem more complicated depending on the chosen service, but it certainly can be a server.
your test is exact what I ment. Because of Airplay limitation of bitrate and resolution, it always plays on a Core because it (bitrate/resolution) is within the specs of the Core. But if the bitrate and/or the resolution of the aiff files is beyond the specs of the Core, these files are not playable in the Music source. This has nothing to do with the B&o app.
f.e. ever tried to play a 32bit WAV on the Core! You simply can't..........
Jakarta, Indonesia
Dear Carolpa,
My AIFF files are 16 bit/44.1 kHz.
 I see... it it does not come from the app, could it be my product then?
Jakarta, Indonesia
mbolo01:
Dear mbolo01,
Thank you for your help.
I will answer with bullets corresponding to the questions:
  • I just changed my phone from iPhone 6s to iPhone SE (2020). For connection, I make no modifications. However, I will focus on the TCP that you mentioned.
  • No, my AIFF files are 16 bit/44.1 kHz
Thank you for your log file. Now, I can take a look more closely.
Carolpa
Test: convert some AIFF to WAV 16bit 44.1kHz. Can you play these files?
mbolo01
Annecy - France
You are welcome.
Is your product the Beosound 35 found in your signature?
If yes, the know limitations are:
Supported audio formats:
MP3, WMA, AAC, ALAC, FLAC, WAV, AIFF. Standard sample rates up to 192 kHz, stereo and up to 24 bit.
WMA lossless is not supported
So there is nothing obvious preventing you to play 16 bits / 44.1 kHz AIFF files.
As Carolpa stated, try with one or two files with other formats such as ALAC or AAC as you are in the Apple world, in order to identify if the AIFF change is the root cause of your issue.
Jakarta, Indonesia
I would like to update on this issue.
I still have my old phone (iPhone 6s, iOS 13) with my old file (ALAC). My old phone could stream smoothly.
In my new phone (iPhone SE, iOS 14), I still store 2 songs in ALAC and all of them worked fine.
@mbolo01,
I would like to ask. How did you obtain the "log files"?
Jakarta, Indonesia
I just tested again with my old phone, playing AIFF through Bang & Olufsen App and it worked fine.
It seems that the problem is in my phone, not really the speaker itself.
I am not sure what should I do. Re-install the Bang & Olufsen app again?
mbolo01
Annecy - France
The “log file” is a live output of the speaker. Assuming the BS 35 has the same software logic, using a browser of your choice you can go to
http://xxx.xxx.xxx.xxx:8080/BeoNotify/Notifications
Where xxx.xxx.xxx.xxx is the BS 35 IP address
Note that if the BS 35 receives no music flow, you’ll have no noticeable activity in this page.
You can try removing the B&O app, restart the iPhone and reinstall the app.
[edit] “Did you build your iPhone from the previous one backup? If yes, I would try adding the AIFF files again from your Music library.”
I’m sorry, you already mentioned that your old iPhone had the ALAC and the new receives freshly converted to AIFF files.
Question: I don’t see any benefit converting ALAC to AIFF, can you explain the rationale ?
I
Jakarta, Indonesia
mbolo01:
I
Got it. I am going to try that!
I set my new iPhone as a new phone, not from my previous phone's backup.
3 months earlier, I bought a new computer and I wanted to re-rip all my CDs to AIFF. The reason is I would like to try listening to AIFF files and see whether AIFF sounds different compared to ALAC
So, I did not convert ALAC to AIFF. All AIFF files were ripped from my CDs.
Page 1 of 2 (18 items) 1 2 Next > | RSS
