Connect Beolab 6000 and Beovox Cona to Beomaster 5500
Not Answered This post has 0 verified answers | 2 Replies | 2 Followers
Norstone
Norstone posted on Sun, Sep 13 2020 7:06 AM
I have connected my BeoLab 6000 to pre out on my Beomaster 5500 and my Beovox Cona to the speaker 1 outputs. They play OK up to volume indicator show 16, but when I try to increase the volume, the Beomaster 5500 turn off. Does anyone no why and if its is possible to fix it?
BR
Norstone
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Hi Norstone
Welcome to Beoworld! This should all work, if the Beomaster turns off when you turn up the volume then this may be a loose connection or a wiring issue with the Cona.
Please unplug the Cona and try again, if this is OK then you may have an issue with the Cona.
Kind regards , Steve.
Steve.
www.soundsheavenly.com
Norstone
Thanks! It was a loose connection and now its all working fine! Kind regards Stein Rune
Page 1 of 1 (3 items) | RSS
