Bathroom solution
Not Answered This post has 0 verified answers | 19 Replies | 0 Followers
1990
1990 posted on Tue, Sep 1 2020 11:22 AM
Hi all,
I'll be moving soon and renovations will start shortly. I'm still in doubt about using KNX or Lutron for control of my systems and eagerly await the Halo launch, but one thing I'd like your advice on: the bathroom speaker.
The bathroom is quite small (5 m2) and features both a shower and a bath. So it can become quite humid. I know Willie is using his M3 in the shower anyway, but what are your preferred solutions?
Anyone with a Celestial in the bathroom? If so, which amp do you use? BeoVox 1 is impossible to find second hand. BeoLab 3500 can be done (I have a NL/ML converter), but I'm worried about the humidity again.
Now is the time to plan all the cabling etc, so please give me some advice!
beojeff
USA
I've used BeoLab 3500s in the bathrooms for over 15 years without any problems. I like having the Essence Wall Remote for control since it's not connected to the electricity. I can even reach from the shower and control the volume, etc.
beolion
I have a wall mounted Beo4 to control my BL3500 in the bathroom.
petermc
Australia
At the moment we have some passive in ceiling speakers (canโ€™t remember the brand) to be replaced by a BeoSound 35 when the bathroom is renovated.
The current in ceiling speakers are connected to a Passive amp which is attached to an Essence 2 controlled by a Essence remote. The amp works well and switches on and off with the Essence.
laseralex
I'm using a Beoplay M5 that sits on the bathroom counter.  I have a Beosound Essence Remote mounted on the wall lust outside the shower door so I can control the M5 while in the shower.  :)
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! ๐Ÿคฆ‍โ™‚๏ธ
Stan
Chicago-area USA
Stan replied on Wed, Sep 2 2020 4:10 PM
I have a M3 on my bathroom counter, but will mount it on the wall in an upcoming remodel.
Daniel
Svinarp, Sweden
I’ve got a pair of BeoVox 1 (mounted in the hidden extra wooden boxes for better sound) in the ceiling. Looks really nice, but sometimes I look at the wall and think a BL 3500 would have been great there. As long as you don’t place it right over the shower there should be no problems with a BL 2000 or BL 3500.
Brian
London/Aarhus
Brian replied on Thu, Sep 3 2020 2:04 PM
I use a Beosound 2.
Jaffrey2230
Washington DC
The M3 is a good natural choice. In my case, I use my P6 as a bathroom speaker. I use it via Bluetooth connected to my phone. It auto connects and it’s splash proof. My bathroom has an inbuilt usb charger so that helps as well. For a permanent solution, I’d pick an M3.
B&O in my life ๐Ÿ˜Š:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
Jaffrey2230
Washington DC
Ah. I was using my Beosound 1 but then got worried that the humidity might effect it. Since I have it on the dock, charging in the bathroom was good and it looks good as well. I switched it for the P6.
stefan
200 miles from Struer
Like many other people here I have a BL3500 in the bathroom - since many years without problems, the only things changed, two new woofers after maybe 10-12 years , and the covers changes from black to white.
The guest toilet got a M3, triggered by a KNX motion sensor, so everytime someone enter the room, M3 starts playing a Tunein Jazz radiostation.
Only problem here was, that guests/friends like the music so much, that they stay at the toilet, just to listen to the music...:)
So I programmed the setup to set the M3 to standby after 5 minutes..:))
Stefan
1990
1990 replied on Mon, Sep 7 2020 3:32 PM
stefan:
Cool! I'll see if I can do something similar for my bathroom. I'll pass on the ceiling speakers and think I will go for a regular speaker :)
Tassos
Athens
Got an M5 on an STB wall bracket next to my sink. Very happy with it no humidity or any other issues.
ngnear
stefan:
Stefan
I would be interested to know how you implemented this. Are you using a Beolink Gateway of some sort or controlling the M3 through the (undocumented) REST-API?
Tim
stefan
stefan replied on Thu, Sep 10 2020 12:22 PM
It´s quite simple - I just used things that are already in my setup.
Beolink Gateway (using KNX driver), of course an ML/NL converter, M3
and a KNX motion sensor, ceiling mounted. The KNX sensor can do a lot, detection of motion for lights, detection of motion for alarm (security),
detection of motion for "HLK" (heating, ventilation, air condition) and a temperature sensor for fire alarm - all these functions have different outputs (group addresses) to control different functions.
To be honest, I just wanted to test the alarm function, because I plan to integrate this into my sec system, and I neede a device to be triggered, M3 wasn`t uses for anything, so I tesed it with the M3 - people liked the music, and so I kept the installation.
How to: KNX sensor`s alarm group address triggers a macro in the BLGW, that starts M3, source tunein, channel 9 (DR P8 Jazz)
second macro (event KNX motion detection stops) command : M3 - standby
this works independantly from the Masterlink system in the house - it is also possible to trigger a ML source on the M3.
Hope this helps...
Stefan
Page 1 of 2 (20 items) 1 2 Next > | RSS
