Beogram 5500 Master Control Panel
Not Answered This post has 0 verified answers | 2 Replies | 0 Followers
PandaSounds
PandaSounds posted on Sun, Aug 16 2020 4:35 AM
Is there any substitute for MCP for a Beogram 5500? Can I use 5000 instead from what I readit does not appear to be compatible. Its a real bummer I would love to use my 5500 that I found.
DMacri
United States
DMacri replied on Sun, Aug 16 2020 4:12 PM
For all functions, you'd need an MCP 5500 or MCP 6500. The MCP 5000 is not compatible. For many, but not all functions, you can use a Beolink 1000, or Beo 4 remote.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, and ambio
Dillen
Copenhagen / Denmark
Dillen replied on Sun, Aug 16 2020 4:41 PM
Beogram or Beomaster?
The Beogram has no support for remote control on its own. It will have to go through a Beomaster.
If you have a Beomaster 5500, you can use a Beolink 1000 remote for the daily operations (including control of the Beogram 5500), and you will need a Master Control Panel 5500 or 6500 (they are identical apart from the model number and finish) for all programming etc. functions.
Page 1 of 1 (3 items) | RSS
