Beosound Ouverture & Beocenter 2300
Not Answered This post has 0 verified answers | 2 Replies | 0 Followers
mr_anders_son
sweden
mr_anders_son posted on Tue, Aug 4 2020 10:24 AM
Beosound Ouverture & Beocenter 2300.
Can you use the same CD mechanism?
BeoVision Eclipse 55"...BeoLab 5 FRONT....BeoLab 4000 as REAR....BV5 HD....Beoplay V1-40....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beosound Stage....Beoplay S3....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H9i Rimowa....6 x H6....Form 1....U70...
Beobuddy
Utrecht, The Netherlands
ONLINE
Most of the times that's possible for the older mk1 version of the Ouverture. But it can be converted to a newer mechanism (used in the mk2).
The newer mk2 version of the Ouverture has most likely the VAM1255 laser and can't be replaced by a cheap ebay version.
You first need to know which laser has been placed inside the Ouverture (or 2300, the one which needs repair). For that you need to dismantle the Beosound.
CB
> You are Here <
CB replied on Tue, Aug 4 2020 1:16 PM
Depending on the age, the laser movement is a straight line or an arch...
Page 1 of 1 (3 items) | RSS
