Netradio stations list update BM5
Not Answered This post has 0 verified answers | 47 Replies | 0 Followers
Fritz
Fritz posted on Tue, Jul 21 2020 11:13 AM
Dear All
The BM 5 Netradio Station List seems to be EOL according to Beo Support UK.
Latest update are from 15-12-2019 / 10-01-2020. This seems to be the last and final.
Brgds/Fritz
Carolpa
My point: Fritz made it sound like the BM5/tv combi is something completely different from the BS5 (the BM5/BS5 combi). I disagree with that vision. Lots of the features were introduced much later when the BM5/BS5 sw had matured.
beolion:
Much easier to scan your music compared to TV
True: other interface, I did prefere the BS5 also.
beolion:
You can assign N.RADIO to RADIO and N.MUSIC to CD
Much later introduced
beolion:
You can assign BM5 as DNLA server
A main difference between the two
beolion:
Spotify integration (when it worked)
A feature introduced almost at BS5 EOL. With lots of hick-ups because of sw changes (at Spotify)
beolion:
You can use the USB input on BM5 with a.aux
Introduced much later
beolion:
You can have the BM5 “on” all the time for quick start up
To my knowledge this was the same for both
beolion:
Ability to attached a CD to play and/or rip CD
Introduced also much later. To me it didn't make sense....... You have a BS5 to listen to Music Files so why the feature to listen to CD's. Ripping and tagging to my preference has always been better with a pc.
SO at the start the BM5 was the successor of the BM1 and the BS5 a new/other interface to the BM5.  Later it was just the BS5 (the combi BM5/BS5) which evolved!
Fritz
Fritz replied on Fri, Jul 24 2020 3:56 PM
Correct..
Many of the highligts were due to suggestions/feedback from customers.
Reason for this was the decission to EOL the BS 4 and BC 2, meaning that B&O would not have a music system.
However this thread is about BM 5 N.Radio Station List Updates.
Brgds/Fritz
Carolpa
Fritz:
True.
So why should the Netradio part of the BM5 be different if connected to a BV from connected to a BS5?
Fritz
Fritz replied on Fri, Jul 24 2020 5:34 PM
That's the way B&O designed the system.
BM 5 standalone with BV connected "system one"
BM/BS5 with or without a BV connected "system two"
Brgds/Fritz
Carolpa
Fritz:
Brgds/Fritz
I disagree. Just because the difference in basic software starting after booting a BM5, does not mean Netradio will be different.
Fritz
Fritz replied on Fri, Jul 24 2020 6:07 PM
But it is, and dont ask me why :)
I agree it would have been smart if using same system.
When BS 5 was put on the marked as a "add on", the BM 5 software soon after was EOL,
and only the BS 5 part of the software was upgraded and updated. Dont ask me why :)
BM 5 was designed for Beo 4, BS 5 was designed Beo 5 and Beo 6
Brgds/Friiz.
Fritz
Fritz replied on Tue, Aug 18 2020 6:04 PM
Dear All
B&O Struer has today updated the Beomaster 5 N.Radio Station list.
The version: 2020-07-15
Beomaster 5 is no longer End of Life.
It's has taken a long time.
repeat BM 5 is no longer EOL..
Brgds/Fritz
Razlaw
Razlaw replied on Tue, Aug 18 2020 7:48 PM
My Beosound 5 shows last update 5/23/20.
Fritz
Fritz replied on Wed, Aug 19 2020 4:36 AM
Beosound 5 and Beomaster 5 is not the same product.
Beosound 5 is an addon to Beomaster 5.
Beomaster 5 can Work as a standalone without Beosound 5.
Razlaw
Razlaw replied on Wed, Aug 19 2020 12:26 PM
Fritz:
Beosound 5 and Beomaster 5 is not the same product. Beosound 5 is an addon to Beomaster 5. Beomaster 5 can Work as a standalone without Beosound 5.
Obviously. But they both use the exact same Beomaster 5. I could connect my Beomaster 5 to my tv if I wanted to instead of the Beosound 5. I see no reason that updates to the BM 5 would be affected by the control/display option selected. If you are correct, I could connect my BM5 to one of my Beovisions and suddenly it would update?
Fritz
Fritz replied on Wed, Aug 19 2020 8:32 PM
The issue is the N.Radio List.
The update list on BS 5 is not the same as on BM 5.
Described in ealier posts.
One need to know the software and hardware difference between BM 5 with or without BS5.
As written before, BM 5 is an updated version of BeoMedia 1.
The update list for BS 5 does not Work for BM 5.
And the N.Radio update list is only updated on request if the a detailed URL for each station is attached,
and will Work on the BM 5 platform.
Razlaw
Razlaw replied on Wed, Aug 19 2020 10:32 PM
B and O advised me today a Net Radio update for a Beomaster 5 is compatible with a Beosound 5.
The reason for my Beosound 5 still having the May list is due to rollouts of the updates occurring at different times for different regions.
Fritz
Fritz replied on Wed, Aug 19 2020 11:14 PM
Sorry to say, Its corrrect with regards to BS5, inkl regions.
BS5 uses another platform. Pls keep BM 5 and BS 5 completely separated.
It's two different products. Not all in the B&O support is aware of this.
Pls read this thread from begning to the end.
Espeacilly if you have a Beovision 9.
Razlaw
Razlaw replied on Wed, Aug 19 2020 11:21 PM
I have read the entire thread and I respectfully disagree with you.
Fritz
Fritz replied on Thu, Aug 20 2020 10:39 AM
To clearify BM 5 as a standalone unit without BS 5 connected., uses N.Radio another station list. .
Try for yourself:
Pls remenber to make a clean reboot without any cables from BS5 connected to BM 5
And use a compatible Beovision to accesc the BM 5, according to the BM5 manual.
Pls revert with date of update  from BM5 as shown on the Beovision in N.Radio mode.
Page 2 of 4 (48 items) < Previous 1 2 3 4 Next > | RSS
