Removing scratches on Beogram 3500 turntable lid.
Answered (Not Verified) This post has 0 verified answers | 1 Reply | 2 Followers
Billonthemoon
Billonthemoon posted on Sat, Jun 27 2020 9:06 PM
Has anyone any ideas on removing scratches from the see through plastic part of the lid on a Beogram 3500 turntable  ?
I have two about 3cm long, not deep but noticeable.
Thank you and best regards. Bill.
Gary
Dublin, Ohio
Answered (Not Verified) Gary replied on Sun, Jun 28 2020 1:47 PM
Suggested by Gary
You can purchase clear plastic surface scrath remover kits at hardware stores or very carefully (try a small test section first before entire scratch):
Clean the surface with a damp cloth, rubbing in a circular motion around the scratch. ...Apply a mild abrasive, such as toothpaste, furniture polish, a very small amount of baking soda or plastic polish to the scratch. ...Wipe a clean cloth over the paste you have added in a circular motion.
Page 1 of 1 (2 items) | RSS
