Beosystem 3 + Beovision 5
Not Answered This post has 0 verified answers | 21 Replies | 2 Followers
emabonacchi
emabonacchi posted on Fri, May 15 2020 6:50 PM
Hello and first of all, scuse me for my bad English.....
I have had a wonderful Beovision5 from year 2002 but it has dead some years ago. Then i bought a Beovision 9 and i have put my Bv5 in garage waiting for repairs.....
Some months ago, i have had in my hands a Beosystem3 Mk1 and i started the job. I want to use Beosystem 3 to drive my old Beovision5.
I thought it can be simply but..... it is not at all!
The first thing is setting up the Bv5 plasma monitor.
I have connected Dvi "Display1" on Beosystem3 to Vga on Beovision5 plasma monitor. Then, i have connected Serial "Monitor" on Beosystem3 to Serial on Beovision5 plasma monitor.
I obviously did setting up "monitor" on Beosystem3 setup-menu (tryed every possible setting about "Beo monitor").
I have spent many and many hours about this thing, but it seems realli impossible........ I have two giant problems.
The first problem is:
When Bv5 plasma monitor is "on", it seems to "disturb" ir signals........ I press keys on Beo4 remote, but they are often not recognized....... When i cut off power and so turn off Bv5 monitor, ir signals are correctly recognised.
The second problem is:
It seems impossible to drive monitor functions "On Off Bright Dim Colors"...... I have connected the monitor via a "null modem cable". Not work. I have tryed to invert pin 2 and 3. Not work........
I am a little tired because i have spent many many time about this thing and i have had no success..... so i am here asking to you if someone know a way to do it.
I was considering idea about buying a new monitor and controlling it via Lintronic, but i woud like to use old Bv5 plasma monitor.......
Can someone help me suggesting some way to do the job?
I hope you have understand me because i know my english is very bad.....
Thank you!
Ema from Italy.
emabonacchi
This is the old Beovision5 abandoned in my garage.........
emabonacchi
This is the Beovision5 plasma monitor connected to the Beosystem3, Ir-eye and a Beolink passive for the center speaker.
emabonacchi
These are the cables from old Beovision5 to the plasma monitor. I see only 3 wires in "Monitor" cable...... pheraps "5v" "gnd" and "signal"?   Can someone tell me how to connect from Bs3 to plasma monitor?
emabonacchi
What is this strange thing around the "dvi" and "monitor" cables are going?...... Is it maybe something reducing interferences?........
emabonacchi
Well, it really seems i have done a difficult questions...... no reply from anyone......
Ok. I think i need to solve using "non B&o" hardware.
Very sad....... very very sad.........
emabonacchi
Any help?
Beobuddy
Utrecht, The Netherlands
Do you have any picture on your BV5 plasma from the BS3?
Kurzschluss
Why not getting a BV4- 42? It should fit into the cabinet.
Simple to connect to the BS3 in 720p...
emabonacchi
Beobuddy:
Scuse me, but my english is a little bad, so i have not understood......
Picture about the Bv5 monitor?
What do tou mean "from Bs3"?
Thank you very much for your reply.
emabonacchi
Kurzschluss:
I have a Bv5-42 screen...... Is not this same as Bv4- 42? Has it some different connections? This is the very important question!!
Kurzschluss
Of course. My BV4- 42 has VGA and DVI connecions and a Serial connector to turn it on or off. This fits perfect for BS 2 or 3...
emabonacchi
Kurzschluss:
My Bv5-42 monitor, has Vga and Serial connections too. So, i think this is the same monitor. I can see pictures on monitor (so, Vga signal is ok) but i have problems on "serial connections" and monitor does not turn on and off and does not adjust brightness and other setting. I need to know serial cable wiring....... I see only 3 wires and i need to know how to connect these.
Kurzschluss
https://forum.beoworld.org/forums/t/21175.aspx
emabonacchi
Kurzschluss:
Beosystem3, works anyway, even without "monitor cable" connected. So, you are able to turn on and off Beosystem3 simply pressing Beo4 key.....
 "Monitor cable", is needed ro control a monitor turning it "on" and "off" and sending a "signal"  in order to "bright", "dim" and other functions. It has only 3 wires. But it seems not working at all with Bv5 monitor. So, i think some differences between Bv5monitor and Bv4monitor......... What is the difference?
Page 1 of 2 (22 items) 1 2 Next > | RSS
