Choice of B and O Sub
Gazfuller
Posts 32
Gazfuller Posted: Sat, May 2 2020 7:16 PM
Hi what’s the best combo with Beolab 18s? What’s the differences between the Beolab 2, Beolab 11 and Beolab 19 which one is the best sub? Thanks
Millemissen
Flensborg, Denmark
Posts 14,610
Imo definitely the 19.
But as with all subs........very depending on the room/room size and the (right) placement - and what they are connected to.
If you preferedly use the setup for movies, you might consider the 2.
mbee
Paris, France
Posts 1,840
mbee replied on Sat, May 2 2020 10:27 PM
BL19 without any hesitation. Best sound with the most settings available.
9 LEE
Eastbourne, UK
Posts 7,217
9 LEE replied on Sat, May 2 2020 11:18 PM
The 19 matches the 18's - the BeoLab 2 matches the 8000's.
Personally I wouldn't mix these up.  B&O spend a LOT of time and effort matching speakers and subs (and speakers and systems) of the same era and always have done.
Page 1 of 1 (4 items) | RSS
