Green Penta Display Wanted
This post has 15 Replies | 2 Followers
Andreas
Germany
Posts 11
Andreas Posted: Fri, Dec 28 2012 10:47 AM
Love my old Penta's but can't find the green display as a replacement over here in Germany. If there is any out there - pls. do let me know.
kind regards
Andreas
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Fri, Dec 28 2012 1:55 PM
Is it broke?
Brengen & Ophalen
Andreas
Germany
Posts 11
Andreas replied on Fri, Dec 28 2012 8:09 PM
Depends how one describes "broke" - its still in 2 pieces wired together, but the display doesn't work anymore.
Dillen
Copenhagen / Denmark
Posts 12,178
Dillen replied on Fri, Dec 28 2012 8:23 PM
Replace electrolytic capacitors.
If the voltage regulator has been affected too, it will of course also need replacing.
Andreas
Germany
Posts 11
Andreas replied on Fri, Dec 28 2012 10:17 PM
Sorry Martin, am not a technician at all.... hat no clue what they are.... never mind how to change them?
Dillen
Posts 12,178
Dillen replied on Fri, Dec 28 2012 10:28 PM
A job for a tech guy, surely.
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Dec 28 2012 10:32 PM
Send it over to me, if not repaired *which I doubt" I have a spare Smile
It's the left one on the picture or not?
Brengen & Ophalen
Andreas
Germany
Posts 11
Andreas replied on Fri, Dec 28 2012 11:30 PM
Yep - exactly the one you mentioned!
[View:http://forum.beoworld.org/themes/hawaii/utility/ Unbenannt von Andy_Schmidt auf Flickr:800:0]
Andreas
Germany
Posts 11
Andreas replied on Sat, Dec 29 2012 11:11 AM
Morning Leslie, send me your details pls. and how much cash to be enclosed pls?
andreas_h_schmidt@web.de
many thx.
A.
Andreas
Germany
Posts 11
Andreas replied on Sun, Dec 30 2012 3:05 PM
Sorry Leslie, deleted your mail by mistake - could u pls. resend it.
Many thx!
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Jan 6 2013 11:55 AM
Andreas, received your display in good order!
I disconnected your display and connected it to "my" board!
Display works...
Your board and display connected to my Penta..
Brengen & Ophalen
Andreas
Germany
Posts 11
Andreas replied on Sun, Jan 6 2013 12:24 PM
Hi Leslie, thx for checking them. I'm kind of puzzled..... Guess the only reasonable explanation is that something else is screwed with my Penta's. Would you have a wild guess what else could be wrong?
Johan
Uppsala, Sweden
Posts 239
Johan replied on Sun, Jan 6 2013 12:34 PM
I suggest you start with the simple things:
Remove the amplifier and check the din connector going from the amp to the speaker. If it checks out ok (i.e., plugged in ok) remove the bottom cover of the speaker and check the connections on the crossover board. Take a multimeter and check continuity through the socket and so on.
/  Johan
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Jan 6 2013 12:43 PM
There's one thing I don't understand Andreas. Didn't you told me or us that you have connected the display with the other Penta and that it it still didn't work?
Brengen & Ophalen
Andreas
Germany
Posts 11
Andreas replied on Sun, Jan 6 2013 12:59 PM
Yep I did do this - but with the Penta which doesn't wok, instead the working one. Additionally I'm not so sure I really picked the right working display and not by mistake the very same one again.  Feel like a fool now... Geeked
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Jan 6 2013 1:11 PM
Oops, these were my thoughts as well. Try the other one you have.....
Brengen & Ophalen
Page 1 of 1 (16 items) | RSS
