Rear speakers - Beolab 3 or 8000
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
omcneill
omcneill posted on Fri, Mar 13 2020 8:57 AM
Hi everyone,
I have a current setup of Beovision 7-55 with Beolab 7.6 and Beolab 3 front speakers. I am adding Beolab 8000s (Mk1) and Beolab 2 but wanted to ask whether I should use the 3s or 8000s for front / rears. Any thoughts appreciated? Thanks.
Millemissen
Flensborg, Denmark
Hard to say - because it highly depends on where you are able to place the (surround) speakers.
Generally I’d go for the BL3’s for that setup.
Millemissen
Flensborg, Denmark
That’s a good placement for surround speakers - the BL3’s will be great there.
Since I am an advocate for having the same speakers all the way ‘round, I’d prefer a set of BL3’s for the front, too.
However, the BL8000 will do fine there!
What you should have much focus on, is the olacement of the BL2 in the room.
Subwoofers are generally hard to place in the room - and a BL2 maybe even more.
Do try out several different places for it before you settle and do some cable management.
It might seem like a lot of work, but in the end you might find a better place, than just by placing it ‘somewhere’.
Trial and error....or success is the golden rule with subwoofer placement.
Page 1 of 1 (5 items) | RSS
