Beoremote Halo, the future B&O remote control
Answered (Verified) This post has 2 verified answers | 615 Replies | 9 Followers
jvezina
Montreal, Canada
jvezina posted on Fri, Mar 6 2020 3:56 PM
The FCC has released information about the table version
https://fccid.io/TTU-HALOTABLE
Have a nice day,
Jean
Ferdinand
Malmö, Sweden
Verified by poodleboy
I saw the Halo at my dealer on Saturday, and although I was already intrigued since the first leaked video it didn’t disappoint at all, knowing that some people do not like it.
I would have a very limited use-case for my BS1, as my other B&O products are too old, but I still want to have one. That it is a great achievement.
There is probably no good rationale explanation why one would spend ca 700$ on a volume remote control. I am now having tough discussions with the FS (wife), as she states ‘you buy Halo I say Hejdå (goodbye) Big Smile
And then my dealer came up with the great idea that I need a Core as well for my BS9000 😀
I love his enthusiasm.
“I have to work on my core” I tell my wife in return Smile
To be continued, and please do see the Halo IRL it is amazingly cool.
Sandyb
Answered (Verified) Sandyb replied on Mon, Sep 13 2021 9:05 PM
Verified by Dion
Which is why I have cut out any B&O control from my music / radio listening - only the speakers remain.
Roon is my control interface - if I must use an iDevice, then at least Roon's interface and software work extremely well - and at times the Linn app(s) too, as I have a Linn streamer / DAC in my main room. The Linn app even shows me a lot of my podcast feeds from TuneIn!
Yes, Roon and a Linn streamer is expensive, but newsflash, so is B&O.
The Halo's design / form factor limits how useful I can ever get.  The screen is too small for searching / browsing in the end. Which implies it was only ever going to be a volume control and starter for predefined experiences. Fine for those who are happy with just that. But with the Moment gone, they're telling you to use your phone / tablet for everything else. In which case, if I am generally constantly having to use my iPad for example, what use is a 700 pound / euro volume dial?
Severed_Hand_of_Skywalker:
The Moment was proof that B&O has no Clue when it comes to software and is why I am so scared to buy a halo now with the "promise" that it will be more useful in the future. They couldn't even get the Moment to work with base features after 2 years of trying.
Carolpa
Carolpa replied on Sun, Sep 27 2020 10:08 AM
Millemissen:
TWG:
beojeff:
Good news: it CAN play linked sources.
How do you access linked sources? Does the HALO has access through a NL/ML convertes (despite listed incompatible on the compatibility chart)?
I am pretty sure that is because the shown sources are sources linked to the BS1!
And - of cource - there must be a converter in the setup for that to be possible.
MM, your assumption is correct
first pic: BS9000 BCL connected and linked to the BS Shape
second pic: Beosystem 7000 BLC connected and linked to a BS35
Carolpa
Carolpa replied on Sun, Sep 27 2020 10:16 AM
MrAndersen:
Happy testing, and as I said, keep it coming good or bad.
Another thought:
Give the possibility to rename the "LINE IN". For example now I have a BS5e line in connected to a BLC. It would be  easier to see "BS5e" in the display than "LINE IN". Especially  because it could also be the LINE IN of the linked product ("Line-in" is shown as the source of the BS35, "LINE IN" as the BLC source for example).
beojeff
USA
beojeff replied on Sun, Sep 27 2020 10:19 AM
Carolpa:
Millemissen:
TWG:
beojeff:
Carolpa-
Have you been able to see every source from NL/ML Converters connected as Primary Linked device and Secondary Linked device? I've found certain sources will depend on whether the converter is connected as Primary or Secondary. I believe the sources are CD and Phono.
mbolo01
Louannec - France
mbolo01 replied on Sun, Sep 27 2020 10:51 AM
NVGAE:
How complicated would it be to implement the Moodwheel
I agree that MW was the best concept since a while and which made me purchase a Moment.
The Halo is not a player, a MW feature in the Halo would require some kind of storage to build an index of the customer music favorites, Deezer and DLNA, which could be huge for some of us, store the track associated moods that would be fetched from either the track metadata or from an external provider such as Gracenote, get tracks that are related from Deezer to be used in the equivalent of the two external rings, process all these informations and expose them is some form of UI that could fit in such small display. This would be CPU intensive thus requiring the Halo to be plugged in the mains all the time.
The Halo does not have the required hardware to support this processing and we all know that the MW is now dead with no more hope that it will resurrect in its current form, if it resurrects, which means the end of the concept for me, unfortunately.
Carolpa
Carolpa replied on Sun, Sep 27 2020 11:15 AM
beojeff:
Carolpa-
I do not use Secondary linked products, because I didn't get the hoped/expected outcome when sources were connected Secondary. (note: this was/is based on early experience of the BLC in NL. I didn't check for changes recently. Because of no software updates for the BLC, I do not expect changes though!)
And YES: all PRIMARY sources of ML products are visible (but not all are made visible).
They are: BS9000 (radio, cd, aux), BS3000 (radio, cd, aux). Beosystem 7000 (radio, cd, phono, a.tape, a.tape2)
EDIT: just did a test. I linked the BLC with the BS3000 as Secundary to the BS35. On the Halo the BS3000 sources were, as expected, NOT shown.
beojeff
USA
beojeff replied on Sun, Sep 27 2020 11:49 AM
Carolpa:
beojeff:
Carolpa-
For me, I can add CD to the local list, but it does not appear on the app, Halo, or BeoRemote One in bluetooth mode when CD is a source on the Secondary Linked device. For the Primary Linked device, I have the similar issue with either Phono or Aux -- I can't remember which. Therefore, I must always assign the BeoSound 9000 as the Primary Linked product (for cd)  and the BeoSystem 5500 as the Secondary Linked product (for turntables). Maybe it's because I have both primary and secondary linked products. I was hoping someone else might confirm that they encounter the same issues.
Carolpa
Carolpa replied on Sun, Sep 27 2020 11:52 AM
beojeff:
see the addition to my previous post.
beojeff:
did you check the boxes "Enabled" of the "Experience mapped to NL" of your BLC?
beojeff
USA
Carolpa:
beojeff:
beojeff:
Of course.
mbolo01
Louannec - France
Carolpa:
I think this is a product feature to be implemented so that It should be possible to provide an alias to the various .IN ports of the B&O products within the product settings itself, and have the App / remotes to leverage it when alias exists.
Carolpa
mbolo01:
I would say it is!
But the chance B&o would update sw of the BLC looks very small to impossible! So that's my reason to ask for having the option for LINE IN aliasses for the Halo.
talking about sw versions, this I notices when looking for some details for the Halo. But my devices all have other sw versions........
https://support.bang-olufsen.com/hc/en-us/articles/360049745891-Which-products-can-be-controlled-by-my-Beoremote-Halo-
Millemissen
Flensborg, Denmark
Carolpa:
My Essence MK2 has a version 1.22.38750   (and is set to automatic update).
To work with the Halo it needs 1.23.40317
VERY STRANGE!!!
mbolo01
Louannec - France
Carolpa:
Got you, I keep forgetting about oldest products with no more updates, sorry, an our Moment are surely in this category now.
Thanks for the sw versions link, looks like global update is coming! All my products are also at lower versions, being the latest.
Razlaw
Razlaw replied on Sun, Sep 27 2020 6:02 PM
Millemissen:
VERY STRANGE!!!
Same here. Also my Core does not have the newest needed update. My Halo has not yet arrived. Hopefully both the software update and the Halo itself will arrive soon.
Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
Carolpa
Razlaw:
no rush! the Halo works also with the actual sw versions
Millemissen
Flensborg, Denmark
How are we to understand the table, you’ve found, then?
Page 23 of 42 (616 items) « First ... < Previous 21 22 23 24 25 Next > ... Last » | RSS
