Beolab 8000 Foam - is it worth it to invest in new OEM parts?
Not Answered This post has 0 verified answers | 10 Replies | 2 Followers
Beosince98
Beosince98 posted on Tue, Feb 25 2020 11:13 PM
I recently repaired my Beolab 8000 and took the rotten foam out in the process. Do you think it is worth it to buy new OEM foam or is simply stuffing some aftermarket acoustic foam in the cabinet enough? What actually is the function of the foam ( I guess minimizing reflection from the cabinet)? Can there be too much foam in the enclosure?
As always, thank you for your help!
Dante
Sao Paulo - Brazil
Dante replied on Wed, Feb 26 2020 6:36 AM
I'm using rockwool, 32 kg/m3 type, in my BL8000 cabinets and the result is great.
Yes, there is a point where  too much material degrates the sound if you block the air flow through the bass pipe.
BenSA
Durban, South Africa
BenSA replied on Wed, Feb 26 2020 6:46 AM
I bought foam, not OEM, but I matched the thickness etc to the original. I also measured and cut it to the original size. I couldn't believe the improvement in the sound afterwards. Made a huge difference.
Beosince98
I just checked out some pictures of the foam. I figure it effectively creates a space in the collum from the bottom woofer up to the start of the bass reflex tube (sealing around the bass reflex tube). This should be easy to reproduce.
mbolo01
Louannec - France
mbolo01 replied on Wed, Feb 26 2020 10:02 AM
Would you mind please sharing some pictures of the work as I’m about to do the same?
Geoff Martin
Struer, Denmark
Just a general heads-up: Mineral wool / fibreglass insulation / Rockwool (whatever name you use where you live) is an excellent choice generally as a material for acoustic absorption that doesn't break the budget. However, if you use it in an area where the air velocity is high (like around the port of a ported loudspeaker), you risk blowing glass fibres out into the air. This is probably bad for human lungs. This is one of the reasons why, when it's used inside loudspeakers, its typical "gift-wrapped" in fabric. (The other good reason is to keep the glass fibres out of the fingers and lungs of the people building and fixing the speaker...)
To answer part of the original question, the purpose of putting acoustic absorption inside a loudspeaker cabinet is to reduce the velocity of the air inside it, thus attenuating the internal modes (or "standing waves").
Cheers
-g
Beobuddy
Utrecht, The Netherlands
The newer type of foam provides a piece which prevents the bass pipe for (audible) resonating.
Just keep it as original as possible.
Beozip
Beozip replied on Wed, Feb 26 2020 1:53 PM
This is the look of an original foam  ...
https://www.ebay.de/itm/Bang-Olufsen-Dampfungsmaterial-Dammung-BeoLab-8000-B-O-BeoPlay-Beo/153684452032?_trkparms=ispr%3D1&hash=item23c84ea2c0:g:DSwAAOSwunNdpIEJ&enc=AQAEAAACQBPxNw%2BVj6nta7CKEs3N0qXgAM5fsrih82mIIiaoKOHrV7VpGDPFukLyavtfnQcMidLwCKfCJzTV3caXNj0e7MDe2ofVZ%2BIcQtG6cLRaHsEGu4PNY8tgXIEWVhEhkDK8Nwt3iWTdbtjIKDlPGb5%2BID2d5s8qjlbN43xhbC3Ee1AiYO%2BGWC6w22Vdif2ehFvCRR%2BOTwvr%2FY%2BIaHee%2B0jVxnGTOxQtjGrJ72i8xsZYW5%2FboTKdyazbTKtylOAWXV0jS%2FSXSreeXHCYW0jmy1umG9G7SEEhfcun5dEpNbsz97NrgXgJcS1j0JnFLz93x4oF2jGqOEt5XdmdqrGJ5fMFJwUwmXTuD3xN99gihrPQ9HCGzr3XXa7VwvhOW6aw5CjMj3qnK5JcTnr9hNZLMnC3m5hC3xU1NkxdnQqL2cPOVUQLswQtJ72nwcoQvB4pti2kKlRB8XCBpuOrGJPoa0XIF1lYKy4fmobnnGbVGNxuuIeU1HzShstOexRECkjN68htfaPkNbISfDJ9j9TRnGmSluB9xTRp9LG1sDCGF2wyML0lEilhg5YW%2BrnOJ9%2Bpj1hUq%2FseSU1CbkY5QNDzFfm2cShQ%2BRrmIIFN%2FbVXjUsICn%2BlVmQmCdddaS9Q16hhFrOfyd62xgh5cR3jBg%2BqBpgn6XYAlc4i%2B47mt9JGX2RUQEosOHVeGZKitTfRsMNPPUvs8AhO5IzHdyM8JgStXMQyHMhioZJN4bLOVhsM%2FG1CiPqXj%2BaQMkQnbrEZRqqghXKnVQ%3D%3D&checksum=1536844520321a082e03268842c18f62397c0eee43a3
Beosince98
This is my result. I think I got pretty close to the OEM foam.
KolfMAKER
The Netherlands
Silver Member
Dear BeoSince,
Just to be sure, something I like to check.
I see two separator pieces of foam. The one that is at the bottom of the bas reflex pipe ... I guess that one has a hole?
KolfMAKER
The Netherlands
Silver Member
By the way, what is the thickness of the newer B&O foam?
Page 1 of 1 (11 items) | RSS
