Beosystem 3 combining with hdmi arc
Not Answered This post has 0 verified answers | 11 Replies | 2 Followers
Beobuddy
Utrecht, The Netherlands
Beobuddy posted on Sun, Feb 9 2020 1:45 PM
Just a simple question.
Can you use a hdmi-arc socket from a different brand tv to feed a hdmi input on a BS3.
So, connect all video sources on the tv and use the hdmi-arc on that for transferring the audio to the BS3?
Would that work?
OldJack
Split
No,Bsys3 does not support hdmi arc
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones A8,A9 keyring,Bottle opener,Wine Set,4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,Beoplay A1,Oppo udp-203, LinTronic.
Beobuddy
I know that the BS3 (I have the mk3 version also) doesn't support hdmi-arc from it's specifications.I also know that other newer brand panels have hdmi-(e)arc on 1 or more sockets.
If I remember correct you can setup the audio on a LG C9 panel to be re-directed to one of it's hdmi ports So, in that case the the LG would act as some kind of source for the BS3 . The BS3 would be then a substitute for a soundbar.
The advantage you would have is that hdmi could handle lossless audio formats when you compare it with digital coax or optical spdif, which support at it's best DD or DTS.
Is handshake or protocol the keyword in which is missing with the above mentioned setup?
Millemissen
Flensborg, Denmark
Whether you’d connect the output/C9 via HDMI or via SPDIF, the result will basicly be the same - the BSys3 cannot decode the lossless audio formats, that might be used with a multi channel source connected to or built in to the C9.
Apart from that, controlling that combo would not be very intuitive.....nothing that I would expect my wife wanting to handle.
OldJack
Split
@MM
Does Bsys3  play lossless audio formats from Deezer,via Google Chromecast ultra,plugged into the one of the Bsys3 hdmi inputs?
Johan
Bolsward, NL
Johan replied on Sun, Feb 9 2020 6:12 PM
Hi, interesting this! It would also mean there is no optical to coax converter needed.
I do not have an answer, but will be following with interestt Smile
(https://forum.beoworld.org/forums/p/38957/295981.aspx#295981)
Regards,
Johan
(Beobuddy, are you keeping the boat steady in the storm?)
Beobuddy
The idea was to ditch the BV9, as nice as it is, but keep the BS3 mk3 behind it.
At this moment I have an ATV4K which streams the digital audio via LPCM into one of my hdmi's. I have an 7.1 setup and can choose the DTS-MA, True HD etc audiotracks on several content and the BS3 displays then " PCM 7.1". I'm in the assumption that this is not possible with you use optical and/or digital coax with 5.1 as maximum. At least hdmi  can carry more audio formats than optical/coax. Correct me if I'm wrong.
Afaik hdmi can transport losses formats.
Beobuddy
Millemissen:
I know, but you have to start somewhere. I want to keep the BS3 mk3..
Beobuddy
Johan:
Big Smile It's rather shaky at the moment indeed..
Johan
Bolsward, NL
Johan replied on Fri, Feb 14 2020 7:09 PM
Hi Beobuddy, as said that I will folow your moves with great interest (as I am planning to do something alike), I do have already two questions:
- do you think any version of the BS3 would be ok? (you said you have the mk3)
- do you think the BS3 can control an LG C9 oled through the rs232c port "svc only" (so no need for visible IR wires)
Regards, Johan
Aussie Michael
Melbourne, AU
Beobuddy:
Yep I’m with you / get what you’re saying
I thought of buying a second life BS3 to do this effectively. To use surround sound with beolabs and with a Sony OLED but with HDMI sources plugged in to the Sony as the BS3 can’t do 4K pass through
I wonder if the BS4 has the same limitations
chickenceo
Silver Member
I am not sure about C9, but my C8 cannot output audio only thru the hdmi arc port. I ended up using optical out and am testing the difference between PCM out or auto from LG.
BL8000, BL10, BL4000, BL2, BL3 (Sold), Beocentre 2, Beosystem 3, LG C8
Page 1 of 1 (12 items) | RSS
