Danish to English translation needed for Tradfri/BLGW video
Not Answered This post has 0 verified answers | 3 Replies | 0 Followers
beojeff
USA
beojeff posted on Thu, Jan 16 2020 4:57 PM
I came across this recent video in Danish. Could someone please watch it and tell me how the guy is controlling his Ikea Tradfri with the BLGW? Many thanks!
https://www.youtube.com/watch?v=QZG5kNBVHjs
baronvejrup
Hi BeoJeff
Im the guy behind the channel Smile
I've had a few who asked for a little guide in ENG - so I wrote a small guide on the video's comments on the channel - please take a look there.
Hope it will help you - otherwise feel free to contact me.
//@BaronVejrup
Find me on YouTube : Bang & Olufsen Teknisk Forum : https://www.youtube.com/c/BangOlufsenTekniskForum
beojeff
USA
Thanks!
So you're using Apple Homekit to run an automation including the Tradfri Gateway when BLGW triggers a light to turn on? I wonder if this could be done by pairing a tradfri bulb that I've never used nor paired with the Tradfri Gateway and instead pairing that unused bulb with the Philips Hue bridge. Would the automation still work if I then completely removed the bulb from the lamp so that it never actually turns on?
baronvejrup
Yes that is correct.!
It would work if you connected a Trådfri bulb to the hue GW and then did the setup as I did.
Dont know if the automation would work if you removed the bulb again, havent tested that in my case.
Page 1 of 1 (4 items) | RSS
