Beomaster 7000 problem
Answered (Verified) This post has 1 verified answer | 6 Replies | 1 Follower
andrew
Sussex UK
andrew posted on Thu, Jan 16 2020 3:17 PM
Hi. I've been using a beomaster 7000 with CD deck and tape deck for some years now. Yesterday - it stopped responding tp the beolink 1000. Totally. So I changed the batteries but that was no good. Then I bought batteries for a 5500 control panel which I used to use with it. And it keeps flashing the message "NO CONTACT".
I am hopelessly non - technical but wonder if this is something that might be easily remedied / repaired? Or is it time to buy another 7000? Thanks!
Andrew
Guy
Buckinghamshire
ONLINE
Answered (Verified) Guy replied on Thu, Jan 16 2020 3:29 PM
Verified by Peter
It may be in A.OPT 0, where it does not respond to IR commands.
With the system in standby, use the BL1000 remote to press SOUND 1 STORE.
And hopefully now it will work!
Guy
Buckinghamshire
ONLINE
Verified by Peter
andrew
Sussex UK
andrew replied on Thu, Jan 16 2020 4:12 PM
Wonderful, thank you! I have done that and it is all back t working perfectly.  Thanks so much! A great relief.
It HAS revealed that the control panel 5500 is working in many ways but not the wheel thing on the left. It does nothing! It used to - but hasn't been used for a long time. Not that it is terrible ly important - I use the beolink 1000 mostly.
Guy
Buckinghamshire
ONLINE
Guy replied on Thu, Jan 16 2020 4:24 PM
Great news - that's the second system on the forum I've 'fixed' today! Smile
Ref the wheel: This works with a small opto-coupler that senses rotation through breaking a small beam of light - I seem to remember that often they just need a clean inside as they can build up dust and dirt on the sensor.  There are also a couple of small micro switches that sense the direction of turn of the wheel.  There may be a thread somewhere about taking it apart and fixing - I think I did it once!
Guy
Buckinghamshire
ONLINE
andrew
Sussex UK
andrew replied on Thu, Jan 16 2020 4:51 PM
Wonderful! Many thanks. Now to get into the back of the master control panel!!!
Guy
Buckinghamshire
ONLINE
Guy replied on Thu, Jan 16 2020 5:06 PM
Here you go: https://www.youtube.com/watch?v=yuTILt4X8iE&feature=youtu.be
There's a part 2 somewhere as well!
Page 1 of 1 (7 items) | RSS
