I don't have any song when I used a non B&O source with the AUX connector, although the AUX run with some other B&O source.
I have the same non result with any other connector of the beomaster, phono/tape1/tape2......
I do not understand why
Hi YL,
Welcome to Beoworld! Which device are you trying to connect to the Beomaster please? If this is an iPod or other portable music player with a headphone socket, then you can use the CD, Phono, Tape 1 or Tape 2 sockets on the Beomaster via a cable like this one:-
https://soundsheavenly.com/bang-olufsen/67-298-minijack-to-aux-in-ipod-to-beosound-beomaster-beocenter-using-aux-din-socket.html#/2-length-1m
The Aux socket is intended for a link to an older B&O TV or a Beolink Converter, so it is best ignored when connecting a non-B&O device to the Beomaster, as it won't work as expected.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
