Beogram 2200 Turntable
Answered (Verified) This post has 1 verified answer | 3 Replies | 0 Followers
ouverture
London
ouverture posted on Tue, Dec 11 2012 5:47 PM
I need to get a new catridge/sylus for my Beogram 2200, the old one is a model MMC 20 E
but would any of these below be OK ??
http://www.beoworld.org/prod_details.asp?pid=727
or preferred for that matter !
it looks like the MMC 20 S and the MMC 20 CL are the most expensive / sought after, are they really that much better, should I pay extra for one of those, providing I can even find one of course
Peter
Earsdon
Answered (Verified) Peter replied on Tue, Dec 11 2012 8:33 PM
Verified by ouverture
You can use any of the following:
MMC3000
MMC4000
MMC5000
MMC6000
MMC10E
MMC20S
MMC20E
MMC20EN
MMC20CL
SP15
The best is the CL, with the EN being the next best of the 20 series. However the alternative,  if you have an old cartridge which is worn, is to get Axel to fit a new stylus assembly. That way you can have anything you want! I have a MMC20S fitted with a Shibata diamond which makes it the equivalent of a MMC5000. The 20S is the least specified of the 20 range. S stands for Spherical, E for elliptical, EN for Elliptical Nude and CL for Contact Line.
Peter
Peter
Earsdon
MMC3000
MMC4000
MMC5000
MMC6000
MMC10E
MMC20S
MMC20E
MMC20EN
MMC20CL
SP15
Peter
ouverture
London
Peter, thanks for that timely reply, the hunt is on !
tournedos
Finland
Just to add, in case it helps you to decide... 20S and 20E (and I suppose 10E as well) are black, while the others are silver Big Smile
--mika
Page 1 of 1 (4 items) | RSS
