Beolab 90 and Beo remote 1
Not Answered This post has 0 verified answers | 26 Replies | 1 Follower
Nodarkatz13844
Nodarkatz13844 posted on Sun, Oct 20 2019 2:41 PM
I want to control Beolab 90 with beo1 remote. IR is connected to master speaker. On remote I have done everything what is required in technical guidance for Beolab 90: setting, advanced, product, Beosound, renamed to Beolab 90. Still no response from Beo 1. Does anyone can help me? Thanks
Razlaw
Razlaw replied on Sun, Oct 20 2019 5:24 PM
There are different or eyes. When I first connected an ir to my 50s it did not work. Maybe check if you have the right ir eye?
Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
Nodarkatz13844
I bought the right IR from my dealer.
I followed all his instructions but Beo 1 remote doesn’t control Beolab 90.
 Any other suggestions? I read in technical guide for beolab 90 that speakers must be paired with Beosound. How?
Razlaw
Razlaw replied on Sun, Oct 20 2019 11:18 PM
I think you can ignore the pairing. I wondered about that myself when I set up my 50s. I am not sure what else to suggest.
You are selecting Beolab 90 with the BR1 so it is the active mode before using? And I suppose it is possible dealer gave you the wrong ir eye? It should be the plain one with no lettering on the buttons.
Here is an old thread on the subject.
https://forum.beoworld.org/forums/t/35599.aspx
Nodarkatz13844
The I got from the dealer is the right
Nodarkatz13844
I got from the dealer the correct IR. Something I am doing wrong but can not figure it out
Razlaw
Razlaw replied on Mon, Oct 21 2019 12:22 AM
Hopefully somebody here with more knowledge than me will be able to help. I am trying to remember, I might have had to connect the ir eye, unplug the 50s, and then plug in again to get them to recognize that the eye was connected.
Nodarkatz13844
I thought about it but never did it . When I am home I will try and let you know. Thank you very much for your help
Nodarkatz13844
I tried to unplug and plug back but Beo 1 is still not working with speakers.
Nodarkatz13844
seethroughyou
UK
Instructions for wiring the iR eye to the BL90 master that came were incorrect. Dealer had to contact B&O and send revised instructions.
Present: BL90, Beosound Moment, Beosound Core, BL6000, Beogram CD7000, Beogram 7000, BS Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, Beocenter 2, Beosound 5, BV5, BV4-50, BV4-65, Beosystem 3, BL3, DVD1, Beoremote 4.
Nodarkatz13844
Thanks, I give this message to my dealer.
Nodarkatz13844
By the chance, do you know correct wiring?
poodleboy
Dealer takes all that money and can't be bothered ensuring the products work. Customer has to use beocare or beoworld. Compare that with other "luxury" brands.
Razlaw
Razlaw replied on Mon, Oct 21 2019 12:42 PM
Nodarkatz13844:
I wired my mine as shown in the diagram in the other thread I posted a link to.
Page 1 of 2 (27 items) 1 2 Next > | RSS
