LG TV + Beosound Stage
Not Answered This post has 0 verified answers | 4 Replies | 0 Followers
Steph
France
Steph posted on Tue, Oct 1 2019 6:21 PM
Hi Beofriends,
If i want to replace my Beovision 10-40, do you think :
- a Beovision Horizon,
- a second hand Beovision 11,
- a LG TV + a Beosound Stage with the Stb Brackets Vesa adapter,
is the best setup ?
My price must be 3500 €
What do you think ?
Mikipidia
ONLINE
Is that price for all time? Or are you expanding the system?
Horizon, definitely NO!
BV11, if you want to expand later.
Bs Stage and LG i would say is the base choice if you don’t want to expand the system.
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
CB
> You are Here <
CB replied on Tue, Oct 1 2019 8:33 PM
Salut Steph
Before choosing the tv, double check the dimension of the WISA frame.
Most big tv needs 400x400, and to my knowledge, the STB frame is smaller.
My 0,02€
Edit: sorry, VESA not WISA
Mikipidia
ONLINE
CB I think you mean VESA.
LG’s 55 and 65” tv’s are both 200 x 300mm , and the 77” is 200 x 400mm.
So for both 55 and 65” lg tv’s work with the stb bracket, the bigger tv’s do not.
Hannes2811
I faced the same decision. I opted for the LG C9 65 inch. WiSa Transmitter is ordered and should then enable a 2.0 or 5.1 setup. As soon as the soundbar is available I will test it and then maybe switch from 5.1 to Soundbar. For the budget, this solution is the better one. (my opinion)
Best regards from Germany
Page 1 of 1 (5 items) | RSS
